Home > General Chat > how hot does a turbo cylinder head get intake side???
clubminiflip
Member #: 54
nr coventry
hotter than an N/A engine but ........ the fuel will cool the inlet charge down somewhat the heat from the exhaust manifold and turbo is the downer, thats why i recommend using the inlet manifold heated takeoff for cooling!
i wonder if anyone has any under bonnet temps ?
What do you mean the charge of the actual casting?
If you mean the casting I'd suggest that it varies in teperature from the throat to the valve, the valve area being hottest. How hot I have no idea, but if you took an average somewhere around the basic engine temperature woule be a fair assumtion.
If you mean charge temperature then depending on setup could be anywhere from 40 to 90 deg C.
clubminiflip
Member #: 54
nr coventry
i'm just after a rough guide as to how hot the casting gets around the inlet ports? would i be more than 100 deg?
i need to get some of those temp strips!
i ask as i have an old 1275 head with a hole about 2-3mm diameter in the inlet port & was thinking "maybe" big maybe!
somthing like that q-bond adheasive cement may fix it, it can genuinely take 180 deg, i've used it on a motorbike steel tubuler exhaust manifold & it held up fine, never broke or leaked
its funny stuff though cast iron! *surprised*D
although i'd have thought youd get more metal expantion contraction on a steel tubular manifold than cast iron?
what do you chaps reckon? yey or ney?
IS that your girlfirend in your avatar??
I've measured temperatures at the spark plug close to 400 degrees C and exhaust gas temperatures at nearly 800 degrees C.
I think that the temperature of the inlet port is heavily influenced by the adjacent exhaust ports and would say that it is likely to go above 180 degrees C.
Advantage
Member #: 1450
Near Paris - France
But if it goes through the IC before, the air is already cooler than the water, aint'it ?
Unless you use a dedicated water circuit for the intake circuit to turn it in a very small chargecooler ?
Rusty by nature
clubminiflip
Member #: 54
nr coventry
it is my mrs aswell lol *surprised*D 16plus dress-size the only way to go lol
You'll not mend a head with any kind of epoxy gobbo.
Even welding or brazing isn't always successful.
I've taken some readings, my under bonnet temps range from 0 degrees above ambient to over 50 degrees above ambient depending on where the sensor is.
All measurments where taken at over 60mph
clubminiflip
Member #: 54
nr coventry
i think i'll have to shelve this idea then LOL
so one of my spare heads are scrap then???? with a 2-3mm diameter hole, bloody hell
Where is the hole through to? Pushrod holes can be sleeved for e.g.
clubminiflip
Member #: 54
nr coventry
mr fenton yes it is next to the pushrod hole, so i can fix it at home????? ie: no money???? *surprised*P
All you need is a press, a valve guide and a drill...Should be quite cheap *wink*
clubminiflip
Member #: 54
nr coventry
what about a hammer with a delicate arm? :)
sounds a top idea! i'll do that! press the guide in a drill to a big enough size for the pushrod to mive freely!
or do i drill to a specific diameter
Ummmmmm My head has been repaired with an epoxy and has been going fine for 3 years.....
clubminiflip
Member #: 54
nr coventry
what epoxy nic, maybe i could combine the two, a drilled out valve guide glued in with some epoxy
i've been really impressed with that Q-bond 7 i thought i was another load of fad junk, it is super strong though!
Your rubberised head hasn't seen much use the last three years though...
I dont know what it is, its a light green/blue colour though
your right ,a holiday is what that heads had really .*happy*
