| Home > Help Needed / General Tech Chat > Sw5 comparison to an avonbar ph2 | |||||||
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
20th Jan, 2010 at 08:56:53pm
Ive currently stripped my engine down which had an sw5 fitted i never actually ran it with the sw5 so i do not really know what it feels like to drive now while i have the engine stripped would it be worthwhile to get rid of the sw5 and go for the avonbar ph2 turbo cam ive tried searching for a comparison but all i could find was how much people didnt like the ph3 avonbar cam and not really a direct comparison so if you were starting a new build what would you buy the ph2 or the sw5 ?? the engine im going to be running is a 1293 with a t2 hybrid with obviously all the necessary upgrades now from searching the sw5 is relatively good in the 998 setup but is it genuinely any good for the any of the 1300 setup
20th Jan, 2010 at 09:37:09pm
What you really need is all the figures for the angles of the cam lobes. I have never seen them for the ph2 or 3 but for all the other favoured Turbo cams (and thats guessing its for a turbo) all the figures are near as damn it identical. Giving the same lift, duration lift at over lap opening and closing angles etc etc or hair splitingly close. Own the day
20th Jan, 2010 at 09:54:42pm
The SW5 and the phase two are like chalk and cheese at opposite ends of the options.
20th Jan, 2010 at 11:04:11pm
sw5... from ac dodd
Edited by robert on 21st Jan, 2010. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
20th Jan, 2010 at 11:07:16pm
not much lift on overlap... but quite short duratrion
20th Jan, 2010 at 11:55:20pm
On 20th Jan, 2010 Paul S said:
The SW5 and the phase two are like chalk and cheese at opposite ends of the options. What is your horsepower target? i would like to be able to run it upto about 180bhp? |
21st Jan, 2010 at 12:33:18pm
go for the hungry lion the phase 2
21st Jan, 2010 at 12:36:49pm
I think that the SW5 does not have enough lift/duration for 180hp. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
21st Jan, 2010 at 12:50:33pm
On 21st Jan, 2010 BENROSS said:
go for the hungry lion the phase 2 and time it in at 108 deg you wont be disapointed Thanks for your help once again :) |
21st Jan, 2010 at 09:21:41pm
your right paul unless mass boost is introduced
21st Jan, 2010 at 11:09:02pm
I put the SW5 in mine back in 97 or so. I think it is a great cam. Ive no idea what power mine had, but dont see why 180 shouldnt be a problem. Just get a good head, 1.5 rockers and a suitable turbocharger etc
21st Jan, 2010 at 11:53:14pm
On 21st Jan, 2010 Paul S said:
I think that the SW5 does not have enough lift/duration for 180hp. Cheers Paul aswell |
