Home > Help Needed / General Tech Chat > Whats the difference?
Arno
Member #: 233
Beugen, Netherlands
I have my car converted to a turbo now, can notice the turbo kicking in at about 3000RPM.
Were my expectations set to high or is a std Metro setup not to much better than a twin SU setup?*blush*
I am running 5psi now, should i block the standard relief on the plenum and boost up?
I really could do with some input here, was it all worth wile?
5psi should see you around 90 horse so depending on the setup, i assume std midget then you should notice a fair difference. power really starts to come with the tweaking though and then you will notice the difference. only way to find out is to make sure its setup well on a RR. you may find it transforms it!
Arno
Member #: 233
Beugen, Netherlands
I shall pull the engine out and fix the oil leak at the back of the crank and get myself some dished pistons. :cool:
The reason for keeping the boost low is to use the standard metro setup, We have not many RR here in Holland, let alone someone with the knowledge.*frown*
Any way, work in progress.
How can I determine what pistons I need? I know the block has been bored at least once.
The intention is to use the car on the road, and doing an occasional night rally.
minimark
Member #: 19
newcastle
at 5psi most well sorted mini`s will see you off.
giallofly
Member #: 164
The Stig..
Newport Pagnell
A decent normally asperated well set up engine is a match for a bog standard turbo lump.
But you say standard metro lump?..just the carbs?..um?
Realy the turbo lump should have a bit more umpf!.
Try upping the boost to 8 or 9 psi..it will be safe for now, especially in these cold conditions.
If you don't have a bleed valve as yet, just get a short length of copper fuel pipe and drill 5/6 holes along it's length. Use this as a bleed valve by fitting it between your turbo and actuator, use jublee clips to fasten it. Have all bar 1 hole uncovered and retest the performance,then 2 holes and so on feeling the boost get higher and the BHP piling up.this acts exactly the same way as a bleed valve.
BE CAREFULL...of detonation, just listen for pinking.
I safely ran a bog standard MG Turbo on 10 psi and was alot cherpier than standard.
Hope i have'nt taught you to suck eggs!
Jon...
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
why will things be better in these cold conditions jon?
Alex
Edited by AlexF2003 on 9th Jan, 2005.
AlexF
minimark
Member #: 19
newcastle
dooh .......
giallofly
Member #: 164
The Stig..
Newport Pagnell
Well Alex, as i is very cold at the moment it acts a bit like an intercooler, the engine draws in very cold air and burns it..
We all know how our cars run well on cold crisp days?
On the same boost my car(modded turbo mini as you know) runs circa 15 degrees cooler on a very cold day on ther same boost.
You are pulling my leg ofcourse.
minimark
Member #: 19
newcastle
they teach that in primary school up here.
just after the 2 times tables
Arno
Member #: 233
Beugen, Netherlands
I was running a decent well setup NA engine with a kent 286 or 386 cam something and a freshly overhauled block.*happy* I have rebuilt it to a turbo now but do not seem to have gained much. I have an incar bleed valve Jon so don't need the pipe you suggested.
However I will install a dump valve shortly, its laying on the table already. I will also block the std ventvalve on the Plenum. So I still have some things to take care of.
Of to Norway now. Cheers you all.
LOL at Mark... I didn't think you even got that far in school?
minimark
Member #: 19
newcastle
no i neva , but at least we know how to get past non leaugers in the cup.lol.
