| Home > Help Needed / General Tech Chat > Compression ratio. | |||||||
26th Oct, 2003 at 12:59:41pm
Howdy, im in the process of building up a turbo motor, but when i worked otu the CR usieng a block thats the standard deck height it works out at around 6.68:1 turbo 16v k-series 11.9@118.9 :)
27th Oct, 2003 at 06:01:19am
Which pistons do you have ? Are they from Japanese engine, 0,5 mm oversize perhaps ? They sure don?t sound like any Mini aftermarket pistons. Normal comp height for Mini pistons is 38 mm.
28th Oct, 2003 at 12:47:34am
duno, there made by accralite, and they have the pistons on file. asked them for confirmation of the bore they should be put in and running clearances etc.
Edited by evolotion on 28th Oct, 2003. turbo 16v k-series 11.9@118.9 :)
28th Oct, 2003 at 06:08:10am
I am running a turbo engine with 73,5 mm Omegas and currently have CR around 7,7-7,8:1. I ran several years at 10 psi boost but since May when I finally got the Dellorto carb sorted have used 15 psi. No reliability issues.
28th Oct, 2003 at 06:12:00pm
Read about your car!.. was the insparation behind my decision to go turbo big-bore.
with the pistons iv got! (73.5mm, 16cc dish and only 33.9mm from the centre of the pin to the top of the crown!)
... ) so ask someone who has solid info.
