Home > General Chat > Just back from the RR
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Maybe not that exciting for some but I'm pretty happy. I finally got the Mini to a rolling road just to make sure the fueling and ignition curve are in the ball park before I do some miles. Everything went well except for things being a bit lean off boost and about 10:1 at 6psi. Got that tweaked and then the pipe to the actuator came off resulting in serious overboost and a IC hose popping off! No damage done and I think I'll rethink how I've plumbed in the actuator. Still, 146 curley whirlys at 3482rpm with way too much boost!
Final results are 106 bananas at 6psi and about 113 curley whirlys so I'm pretty happy. The drive home was nice and got home with the battery getting flat towards the end so I guess somethings still up with the charging curcuit.
Thanks to all on this site that have helped with advice etc! Just thinking about it the other day the info on this site is really invaluable, someone can join up and get all the help they need to build up a car and get it running. Thanks guys!
On 7th Nov, 2008 Nic said:
naeJ
m
Congrats, you'll be upping the boost before you know it! :)
Good stuff *smiley*
Thats fairly decent grunt for 6psi. Congratulations!
How did you find the turbo?
He opened the bonnet and looked behind the block I guess....
Baboom!!
Groan, my dad makes jokes like that
i think they are of a similar age nic ..
Jay#2
Member #: 648
Really good thanks Nic, it's a spoolmonster (even with a 3.1 FD and tall first theres hardly any lag) and that combined with a bit of Benross magic on the head it's nice an tourquey. You don't nead to drop gears to overtake, 4th will do!
naeJ
m
Indeed, its amazing on the road!
Have fun!!
good going for 6 psi boost what turbo is it?
Jay#2
Member #: 648
It's Nic's old one, basically a T2 from an R5GT with a reprofiled comp wheel and housing and 360 degree bearing. Mirage supplies them. Intercooler is a Cosworth 2WD, head is a Benross special with conserative porting and 33.3/29.5mm valves and cam is an MED one similar to the phase 2. I don't see me getting more than 140-150 bannanas on higher boost settings but torque should be good.
naeJ
m
nice one, sounds good and safe :)
stefaz
Member #: 1656
stoke-on-trent
congrats there mate, they look like good numbers
Flame Red
Member #: 6267
That seems a good result, sound like a similar spec to mine as well. It makes the 4 hours I spent today sorting out my oil return seem a little more worthwile.
Got to be good to be the other side of 100
Jay#2
Member #: 648
Yeah it is! When it over boosted it must have run near 15psi for a few seconds and it sounded rediculously powerful. At least I have an idea now what it will be like when I hoik the boost up.
naeJ
m
turbominivanman
Member #: 1504
Westbury, Wiltshire
Well done mate.
Another member of the 100 plus club !
Richard
Edited by turbominivanman on 25th Jan, 2010.
I'd be happy with that
