Home > Help Needed / General Tech Chat > This look ok to you ?
G67ATP
Member #: 81
hi guys im still searching for a turbo lump and believe i may have found one but was wondering what you thought about it :
http://www.migweb.co.uk/forums/showthread....threadid=103944
The bloke selling it is on the mini classic board and his names turbine boosted anyone know of him here is a link to the article
http://pub108.ezboard.com/fminiclassicfors...icID=8995.topic
i gotta find out whats is and isnt included but from my (turbo untrained) eye it looks quite good
Any Thoughts
welcome
Dave *smiley*
Dave Fletcher A.M.I.M.I
For a low mileage engine it looks well messed with. I.e. the carb's been sprayed black *oh well* gearbox etc has all been sprayed over.
Also looks to have a early non-verto starter and a late type dizzy. I would think it looks a bit mix and match to be honest but its hard to tell from the pics.
No oil cooler fitted and no feed for the turbo on the block so wondering if its a turbo block etc. Or someones changed alot of bits over, once again meaing its been messed with a bit.
Just be careful buying un-run engines. They can be very expensive.
Any 1275 can be made to run a turbo if you were thinking of rebuilding the engine anyway. Then you just need the turbo, carb etc.
Engine number *should* tell you a fair bit.
