Home > General Chat > Steering Rack Mounting Bracket Removel
longy
Member #: 2727
Bicester
I was happily grinding away yesterday and thought to myself hhmmmmmm that looks a bit chunk (the bracket i mean). so i thought what if it was replaced with some ally brackets. before i could think id whipped the bracket off and weighed it. it comes in at 525g.
Now its off im thinking was it a good idea, have i jeopardized the stiffness? will the ally brackets cope?
I just want to hear your thoughts.
Longy
Replace the chunky metal bracket with Ally ones3 Votes 3 Votes - 0%
Weld it back on11 Votes 11 Votes - 0%
1972 998 TURBO SLEEPER
longy
Member #: 2727
Bicester
This weigh loss lark is getting infectious
I voted weld it back on, but would have gone with option 3 - drill lots of holes in it and then weld it back on.
Have you bought garage weighing scales yet?? I did at the weekend *indifferent*
Light weight it great but safety is better - stick it back on and leave it alone.
Paul
longy
Member #: 2727
Bicester
thanks for the advice guys
I'm sure the whole bracket will help prevent flexing of the toe board so would be tempted to keep it
Fit one of these babies:
http://mk1-performance-conversions.co.uk/s...?forumid=250646
miniminor63
Member #: 672
The oversills police
Oslo, Norway
eh, Vegard? I think you misunderstood this post
I'm not entirely sure what you are on about TBH.
I keep meaning to tap Mark up about those brackets. They are very good.
miniminor63
Member #: 672
Oslo, Norway
The GTMs bolt the rack onto the subframe, getting rid of this bit completly.
Not sure if any mods are required to the subframe though.
seems a sensible mod anyway as the rack is less likely to move relative to the wheels.
longy
Member #: 2727
Bicester
Interesting wil i didnt think of that
Certainly worth thinking about...
I never thought of removing these, think im going to do the same and use some of those plastic type ones that cossierick has used.
longy
Member #: 2727
Bicester
dont suppose you've got a link to those plastic brackets Mike?
codd_coupe
Member #: 1772
Leicestersheershire
You can get the bits to do the GTM conversion from:
Alan Britton
SPECIALIST ENGINEERING
145 HERNE ROAD
RAMSEY ST MARY'S
HUNTINGDON
CAMBS
PE26 2SY
01733 844839
rossabitz@btconnect.com
You just need a couple of the U bolts and some aluminum blocks, so that the u bolts pull straight when they tighten up.
I'll try and take a couple of pictures of my set up when I'm next in the garage.
Tim Rowe
"Is est totus perfectus per fumi quod speculum"
GTM Coupe Turbo
longy
Member #: 2727
Bicester
Cheers Tim,
these are similar to cossierick's,
http://www.rallydesign.co.uk/product_info....roducts_id=7335
i was thinking something similar to anti-roll bar mounts, only using one half
While your bracket is off the car can you chuck it on the scales??
codd_coupe
Member #: 1772
Leicestersheershire
You just need to be able to clamp it without trying to bend the rack.
Tim Rowe
GTM Coupe Turbo
miniminor63
Member #: 672
Oslo, Norway
Alan Britton
145 HERNE ROAD
RAMSEY ST MARY'S
HUNTINGDON
CAMBS
PE26 2SY
01733 844839
I would be very interested in seeing pictures of this!
me too
longy
Member #: 2727
Bicester
andy read the thread lol, it weighs 525g
doh!
Yes these would do.
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
Not sure what cossierick has but by "plastic clamps" do you mean Stauff clamps?
