| Home > Help Needed / General Tech Chat > fitting rear window chrome strip | |||||||
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
27th Jan, 2010 at 12:52:45pm
just a quick one really. fitted the rear rubber and window but cant get the the hrome locking strip in.
cant beat a good blowout. |
27th Jan, 2010 at 01:09:46pm
stick the filler strip in the hole in the tool, then the head of the tool in the seal, opening the seal where the strip sits, then just run the tool round the rubber pushing the strip in as you go.
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
27th Jan, 2010 at 03:27:41pm
I found it easy with the tool, just pushing the strip along. Helps alot to warm the filler strip up first On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
27th Jan, 2010 at 11:25:48pm
cheers done it now. loads of fairy liquid. just couldnt work out how to get the first bit of the strip in. :) pretty easy once i knew On 27th Apr, 2010 Rick.SPI said:
28th Jan, 2010 at 09:44:12pm
I use Autoglym rubber care nice and slippy and wont rot anything I run a supercharger and I don't care the TB is on the wrong side.
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
18th Aug, 2012 at 11:26:44am
bumping this a bit :p
Edited by t@z on 18th Aug, 2012. |
![]() 293 Posts Member #: 10010 Senior Member Northants |
18th Aug, 2012 at 12:07:04pm
Yeah there is, but its not easy! Basically have to force it in with whatever you have to hand, something like a flat head screw driver can be used. Although I would not recommend this as it is a complete pain in the ass, just get the tool and make life easier |
18th Aug, 2012 at 12:14:58pm
bend some wire from a coat hanger into the same shape as the tool and hold it in a pair of pliers On 11th Feb, 2015 robert said:
18th Aug, 2012 at 12:34:33pm
thanks i will give that ago, if not a friend has one but its a 70 mile round trip :p |
18th Aug, 2012 at 01:00:46pm
Either wait for the tool or fashion something up, but don't use a screwdriver as all that will happen is you will butcher the rubber and probably slip and scratch your paintwork.(voice of experience).
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
18th Aug, 2012 at 06:54:07pm
Toms right with the screw driver, your almost sure to slip out of the rubber right into that nice paint work.. Main Build
