| Home > Help Needed / General Tech Chat > Standard 998 Issue? | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
28th Jan, 2010 at 08:15:54pm
Hi All,
28th Jan, 2010 at 09:06:23pm
Is the float chamber leaking? On 20th Oct, 2015 Tom Fenton said:
28th Jan, 2010 at 09:20:40pm
Blowing down the breather will just push fuel out of the jet which is why it's starting I guess.
28th Jan, 2010 at 09:29:13pm
have you blocked the over-flow off, I did this when I first fitted a Hif44 and it wouldn't flow any fuel.. I run a supercharger and I don't care the TB is on the wrong side.
29th Jan, 2010 at 08:32:43am
Sticking float/needle valve that the fuel pump can't overcome? |
29th Jan, 2010 at 08:38:24am
I'd go with the blocked/resticted pipe between float chamber and jet. Sometimes the inner plastic bit can get kinked (unseen from the outside) or crushed where it is sealed to the float chamber.
29th Jan, 2010 at 10:19:24am
Cheers guys, I too was thinking a restricted pipe, but will give all suggestions a go.
29th Jan, 2010 at 06:06:03pm
It works...
