Home > Help Needed / General Tech Chat > what brand OE metro turbo clutch do you rate the best to buy????
clubminiflip
Member #: 54
nr coventry
what clutch do you think is best for the job chaps,
QH
Luk
AP lockhead
the red ebay ones?
Well, i'm putting 112hp through one of these:
[url]http://www.minispares.com/Product.aspx?ty=pb&pid=32713&title=CLUTCH KIT AP PRE 90/VERT...[/url]
EDIT: Why won't Minispares links work? search Minispares on GCK151AF
Edited by Paul S on 29th Jan, 2010.
clubminiflip
Member #: 54
nr coventry
would you say this is a stronger setup than the old turbo clutch, is the pedal a bit stiffer (no great shakesif it is)
thankyou
I've not had the opportunity to compare the two. It "feels" like a standard clutch, although the bite point is a bit too close to the floor.
clubminiflip
Member #: 54
nr coventry
anyone else with an iprated or standard turbo clutch what brand is best?
minispares dont stock QH anymore due to fitting probloms & not consistenly working as you would expect?
The Minispares Ap 'turbo' clutch has a slightly thinner spring compared to a genuine AP Turbo clutch.
I know this as I am using one of each on my RTS. Might be a bit much lol. We shall see *happy*
You will only be able to find a genuine AP turbo clutch NOS The Minispares item is identified with a dark blue dab of paint while the genuine item is identified with a light blue dab of paint
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4510
clubminiflip
Member #: 54
nr coventry
cheers sprocket!
i think a replacement is going to be the order of the day unless i find a NOS one ,god-knows where to start looking for one?
gonna have a red of that link, cheers bud
i know minits had a uprated verto clutch made that has a bigger clamping force than the OE turbo clutch but i'm putting it in a metro which has a cable clutch & i think it may add too much stress to the cable! as the chap at minits said it had basicly double the strength in the spring plate!!!!!
he recommended that the OE replacent should be enough
anyhoo off for a read of said link
metroturbo
Member #: 989
North Yorkshire
From what I have heard, the cable clutch isn't any good for anything other than a standard clutch. You are better off getting the hydraulic verto clutch parts from a MK 1 Metro.
mayoturbo
Member #: 1395
chepstow
I found the cable clutch useless, the self adjuster is made of plastic and fails. I have converted mine to hydraulic now
clubminiflip
Member #: 54
nr coventry
what was involved fellow metro dudes *surprised*P
if i have to mess around swapping clutch pedals i cant be bothered but if its a case of a slave cylinder & hydraulic clutch arm on the frying pan & adding a clutch cylinder i may be prepared to do the work
where do you put the clutch master cylinder as there aint much room on the metty next to the master cylinder/servo????
i'm tempted as i have a slave cylinder/verto-hydraulic clutch arm & a braided clutch hose from my mini?????
could i use a mini clutch master cylinder
any chance of a pic chaps with metros????
We did it on our van. You need the whole pedal box, base plate, master cylinder, slave cylinder and hoses
We are using a pre-verto clutch so ended up needing a custom hose as the metro master cylinder is M10x1 thread and the mini is 3/8 UNF
clubminiflip
Member #: 54
nr coventry
i think its stock clutch n cable for me i cant be arsed to do all that, its only my daily
i may give stuart gurr a bell if i need a clutch in this thing i 'll know by monday eve hopefully
While digging out the door bars, I think I have a new ap turbo clutch plate in the garage from before I went pre verto.
clubminiflip
Member #: 54
nr coventry
keep that for me then bro if its a verto jobby! you diamond! i'll bring my jlt bearb with me when i come pick the bits up!
I'll measure it up when I'm home again. I know it was the 180mm not 190mm plate though.
Anything else you need that I may have?!
clubminiflip
Member #: 54
nr coventry
check the colour of the dab of paint on it
Are you talking about the friction plate? As everyone else on here is talking about the pressure plate*happy*
Bollocks! Ok, I don't have one. *hehe!*
clubminiflip
Member #: 54
nr coventry
no worries, i think i lost the plot with this clutch
