Home > General Chat > gearbox help needed - 3rd motion bearing clearence to small
RED850
Member #: 89
Sydney Australia
Hi all,
just about to finish the gearbox build up and when I go to measure the clearence on the 3rd motion shaft bearing retaining plate, I only have .04mm and the lowest spec in my manual says .13 to .15mm.
reading the "use shims" section it looks like it need around .02mm clearence.
do you think .04 is too much?
any thoughts.
Edited by RED850 on 31st Jan, 2010.
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
