Home > General Chat > topic what valve spring compressor do you use?
clubminiflip
Member #: 54
nr coventry
lads what valve spring compressor do you use?
i have two a draper & a small 8" long sykes pickivant
i need one inbetween the sizes i have as they are both not really correct, i cant explain in text on here why, you have to see them to know
let me know what make & size you use
one off the shelve at halfrauds not sure of the make its done every valve for me in the last 6 years
Asphalt
Member #: 1027
Germini, black forrest
DIY :) wet cloth into the chamber and puhs (pillar drill) http://img261.imageshack.us/img261/9936/26689319.jpg
[X] nail here for new monitor
tadge44
Member #: 2500
Buckinghamshire
hammer to take them out and pillar drill to put them back
Advantage
Member #: 1450
Near Paris - France
Pillar drill all the way !
Rusty by nature
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
halfords sykes pickivant thing, the biger ohc one as the one thats actually for a mini type head is rubbish and mostly bends.
thayre all a bit to bid so a socket in the combustion chamber helps a lot
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
using a glow plug or lambda style socket in the drill press is the easiest, as you can stick a magnet through the socket to get the collets out
turbominivanman
Member #: 1504
Westbury, Wiltshire
Draper.
Double handle job, one at each end. Bout £30. Fab.
Richard.
