Home > Show Us Yours! > Pinky's build thread
nutter driver
Member #: 47
Not very sunny swanage
looks really good.... im watching carefully, im also doing this, im about as far along as you are making pulleys etc, and ive got my cambelt all on and running, but now seem to have stalled for about the past 10 months due to lack of time......
looking forward to seeing your progress, it may inspire me!!
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Bought some ali plate and did some good old drilling and filling.
Im surprise how nicely it turned out and its so much lighter that the std steel one.
It was then fitted to the mock up engine and the bottom pulley was installed and the holes marked for the oil seal holder. No pic as i was to busy concentrating, sorry.
Im thinking of changing the counter sunk holes to counter bored, that was each holder will have a slight amount of play and will allow the oil seals to centralise on there respective runners and hopefully reduce the chance of oil leaks.
"Try to take over the world!"
So long as you have a good gasket and/or sealer behind each plate, allowing them to "float" while being tightened up to let the oil seals centralise themselves seems a very good idea IMO.
Same as the standard timing chain cover - the right way to fit one is to put the bolts in loosely, then fit the crank pulley/damper to let the seal in the cover centralise itself around the pulley, then tighten the bolts..... How many people actually do that ???
(waits patiently for every one to say "of course we do" :) )
evolotion
Member #: 83
Glasgow, Scotland
of course we do..
Denis O'Brien.
And I hope that you wont prove wrong too....
pinkyandnobrain
Member #: 2588
Well picked up this little thing today.......
Cheers Wolfie !
pinkyandnobrain
Member #: 2588
Would anybody hazard a guess at which one it is ? First person to get it right gets a 100 scene points !
It's a GT17???
GT 2056 ???
Advantage
Member #: 1450
Near Paris - France
GT 154? off a diesel ?
Rusty by nature
I'm with Rodderick
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=342909
On 29th Jul, 2010 apbellamy said:
I'm with Rodderick
So you cheated too...... but you were too slow.....
The best cheats allways get in first :)
I tried earlier, but my searching skills where not quite up to it this morning...
sturgeo
Member #: 1778
Northants
Hmm, whats that off? rather different to our 2056.
pinkyandnobrain
Member #: 2588
Welldone Rod ! I'm not sure which car its off of but I do quite like the funky snorkel on the comp side !
philc
Member #: 1346
bromsgrove
looking a good build, i have a similar problem with the head bolts, so just deciding what to do.
On you head you have three small water holes that need welding, otherwise it will not be a complete dry deck, i missed these and had to have them done.
pinkyandnobrain
Member #: 2588
Cheers philc, I did notice that they havent been welded. Ill sort it out at some other stage.
pinkyandnobrain
Member #: 2588
Tiny update.
Top plate has oil seal holes in it now.
Waiting for my crank damper to arrive from the UK and then the final balancing can be done, once thats sorted I can check if my plates and pullies fitand line up.......
pinkyandnobrain
Member #: 2588
Another small update.
Jackshaft oil seal holder with its o-ring in place.
And then I had a play with the macro setting on the camera
One of the valve covers bobins with its o-ring.
pinkyandnobrain
Member #: 2588
Took the top plate to a friends place to cut out on his bandsaw.......
Dont think the bandsaw is going to be the same ever again.
Next was to sort out a timing belt, which proved rather difficult as I measured it incorrectly but a quik search on the net provided me with the correct number of teeth. So....
All the pulleys line up except the crank pulley which needs some shiming but I did expect that.
The next step is to get a mock-up engine and gearbox in the car so I can start working out where the plenum, intercooler, exhaust manifold and turbo will go.
pinkyandnobrain
Member #: 2588
Well late last night i got the mock-up engine and gearbox in the car.
The car is still super dirty but I really wanted to see what it looked like.
Not much space for the turbo. Im going to mount the turbo facing up, similar to Joe's 7 port and the Don.
Apart form that Ive started to realise that there is very little space to play with but Ill get more stuck in this evening. Maybe give it a wash......
you need to brake out the T-cut *hehe!*
pinkyandnobrain
Member #: 2588
Cheers Andy. The car has been standing for about four years so its alittle dusty.
Anyway here is my first attemp at a CAD version of the plenum. Looks cool but its ti high and will need a massive bulge in the bonnet.
So I moved on to the exhaust mani and the positioning of the turbo.
Like it was made to fit.
looking good;
I Drive A VR6
Member #: 9190
Located in the Bermuda Triangle
I approve of this thread!! Nice work guy!
I like the sound of a narrow six!
