Home > General Chat > adjustable tie bars with metro four pots?
welshdan
Member #: 1111
s wales
hi, just a quick one. think i read somewhere before that some tie bars cannot be fitted with metro four pots due to clearence issues?
if i remember you cant fir the square ended ones, but can fit the round ended ones.
can someone confirm this for me before i tighten my front suspension components up?
thanks
t3gav
Member #: 229
Gavin@minispares.com
kent
Never had a problem on my car with this setup.
MrTurbo
Member #: 814
Utrecht, The Netherlands
Never had any issues as well, I can't think of any reason why the round or the square type wouldn't fit with metro 4 pots
t3gav
Member #: 229
kent
Actually ignore me, the ends of my tie bars aren't completely sqare...
haimesyboi
Member #: 5702
Cornwall
ive got square heavy duty ones on metro hubs with metro 4 pots.
welshdan
Member #: 1111
s wales
ok thanks. will try them then. have two sets. the square set are powder coated so would like to use them. not changing the brakes yet to try as the engine is out at the mo
When at ride height they will be nowhere near.
While assembling it all and the suspension is at full droop it may be close
Paul
welshdan
Member #: 1111
s wales
it did look close when i mocked it up, couldnt fit the callipers as the car still has mini drive flanges fitted.
thanks for clearing this up. will get everything tightened up when a couple of bushed that im waiting for arrive.
