Home > Help Needed / General Tech Chat > door gaps
sam_shelton
Member #: 251
Nottingham UK
Hi I am trying to replace my hinge panel and A panel, does anyone know what the optimum panel gaps are? Any tips on replacing hinge panels and a panels?
Doodmeister
Member #: 149
Alberta, Canada
I always work on the gap being the same as the width of a pound coin and thats 3.1mm or as close as i can get it.
The best tip would be to buy heritage panels not cheap aftermarket stuff.
sam_shelton
Member #: 251
Nottingham UK
I have heritage panels, I know they are not cheap but I have had bad experience with repro ones in the past. Is it best to try the door without shims first or fit it with shims?
Doodmeister
Member #: 149
Alberta, Canada
I always fit them without because i find they settle over time and need a shim or two to get them correct again.
