Home > Technical Chat > avonbar phase 3, 8k rpm, Gt2056?
Nick
Member #: 154
Midlands
After seeing the way my Gt20 pulls all the way up to 6500rpm with no signs of stopping i'm wondering if it's worth doing a few crank/rod mods to safely push it up towards 8k rpm to make full use of the turbo?
that got me thinking though, does the ph2 cam i'm currently using run out of steam before then? would it be better to switch to a ph3? keep the ph2 and fit 1.5 rockers maybe?
any opinions chaps?
Brilliant. I dont have any info am afraid nick but im definitly interested on peoples comments.
Rick
ps, i think flan has a ph3 or james h
pps , I used to take mine to 7k but just seamed to want to go even more, that was std t3 and 266 cam 1.5's
Edited by cossierick on 1st Feb, 2010.
i think it will be crap,
I think somthing custom on a wide LCA from piper will be better.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Nick.
Don't know alot but seem to recall the Ph3 got a slating on TM a while back.
Richard.
iirc it was very peaky and not suitable for the strip or road
JF whacked one in i think
evolotion
Member #: 83
Glasgow, Scotland
not familiar enough with the gt20, but generally speaking the larger and free-er flowing the turbine the more akin the tuning is to nat-asp than turbo. in terms of conventional wisdom :)
Denis O'Brien.
Thinking out loud here, what about re-timing the phase 2 so it's retarded by about five degrees or so? Won't help the bottom end & idle but should up the rev range and let you see how the GT20 preforms at higher revs and if you don't like it you and put it back and it's not cost you a penny.
Edited by Rob H on 1st Feb, 2010.
