Home > Help Needed / General Tech Chat > Reaming out the bush for radius arm pin
Is there a set size to ream this to? Or should I just take enough off to give it a nice sliding fit?
Pin measures 0.810
Got a 25 to 27/32 H9 reamer that should do the trick
Joe
you ream it untill the pin just slides / drops through,
Cheers carl
flash git lol, im a rough bastard so by hand will have to do
LOL
Actually i found that pic on TMF earlier.
Rough is not reaming by hand.
Rough is reaming by a reamer welded to a socket, driven by a windy gun.
I have not done this. I have seen it done. In fact a place I worked at, it was custom and practice!
sounds fine as long as its lubed well...
