| Home > General Chat > Mambas and coiloves rubbing | |||||||
4th Feb, 2010 at 11:22:49am
Has anyone alse had a problem with there tyres rubbing against there coilovers on the back?
Edited by matty on 4th Feb, 2010. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
4th Feb, 2010 at 11:34:13am
Id want a minimum of 5mm I seriously doubt it! |
4th Feb, 2010 at 01:43:44pm
Cheers Paul, thats what I was thinking. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
4th Feb, 2010 at 03:12:05pm
I'm not sure if the outside diameter of the spring varies between the 1.9 inch and the 2.25 inch internal diameter springs, but could that be causing an issue?
4th Feb, 2010 at 04:00:38pm
Not too sure on the spring rate. I'll try and have a look. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
4th Feb, 2010 at 04:42:25pm
I had a shuddersfield beam with offset spax on my old cooper years ago, it was fine with the std rover minilights and yoko 510s, but i had a nice set of 6" minilights in white given me so thought id whack them on
4th Feb, 2010 at 07:36:23pm
Have you turreted the rear wheel arch tubs for the coil overs?. I had to on my old shell with a speedex beam (same as yours)? The KAD beam runs a wider track and you don't need to however. On 5th Sep, 2011 Vegard said:
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
4th Feb, 2010 at 07:40:05pm
What does this KAD beam look like? Do you have any info? |
4th Feb, 2010 at 07:43:24pm
On 4th Feb, 2010 Nic said:
What does this KAD beam look like? Do you have any info? It is a straight bit of box section with two rose joints that have in-situ capability for track with a bracket at either end.
4th Feb, 2010 at 07:47:18pm
Ah ha cheers
