Home > Help Needed / General Tech Chat > Piston choice
pulse
Member #: 2011
Ashington, West sussex
Hi people just looking at placing my order from Avonbar for my pistons and camshaft set etc and i came across another set of pistons on there. i was going for the OMEGA +20 with a 10cc dish but i have just seen the forged +20 but with a 14cc dish?
now here is my spec I'm building to and aiming for around 170ponnies? maybe pushing 200 with gas (I'm aloud to dream:-p)
1275 +20 1293cc
Omega +20 10cc
Rebuilt T3 turbo (as a short term thing to see what its like but looking at a modern turbo)
Ported manifold and elbow with wide band sensor
Standard flywheel, (lightened and balanced)
Standard Con rods inc ARP Bolts, (balanced)
Steel Center main strap
Turbo verto clutch setup, (lugs machined down)
Avonbar CAMSHAFT PHASE2 (turbo) kit inc Double valve springs, and followers.
rolling rockers(1.5),
28cc chambers,ported and polished, bigger valves (looking at sizes) but am looking at benross head
Fuel regulator
8mm Fuel lines (both feed and return)
Minispares close ratio SC gearbox with X-pin diff,center pick-up,SC drop gears
cold fusion nitrous kit (wet) + (25bhp shots)
Punto GT Fmic
Avonbar Uprated water pump
Avonbar uprated Oil pump
MegaJolt ignition
now i will be running a dual stage boost controller and running low and high being and high being around 18-20psi? (will the t3 take that?) so would it be best for me to do down the forged 14cc dished pistons rather than the 10cc?
many thanks
Edited by pulse on 4th Feb, 2010.
The cast 10cc omega's seem to take a lot of punishment. So if budget is a concern stick with them
If you have 14cc pistons you might not need as big chambers in your head either.
You will also want an RTS clutch you you are staying verto. or a good pre-verto setup if not. Standard/Turbo verto will not hold 170bhp
Also 20psi from a T3 may mean you need a hybrid item.
20 psi ,is about 2.4 on the left scale , so easily achievable with a stock t3 ..bhp scale is about 100 to 190 bhp at that boost .
Edited by robert on 4th Feb, 2010.
pulse
Member #: 2011
thanks Robert really helpful image
Is this a standard metro T3 robert? With .25 AR exhaust etc?
Turbo Tel
Member #: 588
Delaware, USA
As someone who lost 2 sets of cast pistons (total cost 400quid+) I would advise really thinking about the forged ones.. add up all that stuff you listed and I'll bet you will find that the extra 200 quid is only a fraction of the total cost.. and you can go do whatever you want without worrying about it.
Did you price out the accralites from Avonbar??
Terry
pulse
Member #: 2011
the forged ones where only about 50quid more i think and i will be going down that route as you said its only a small amount to pay for something that could make a big difference
yes most of my parts are coming from avonbar as thats the only place i can find that do the pistons and bits i want
edit: see here
http://www.avonbar.com/prodDets.aspx?pId=2234&br=13_116
Edited by pulse on 6th Feb, 2010.
i noticed that avonbar are selling accralight and omega's in 18cc dish, i had no idea that omega's come like this thought it was JE and accralight only
I just bought a set of these:
http://www.med-engineering.co.uk/product_d...25&vlang_id=169
pulse
Member #: 2011
they look good but why are the cheaper? and come with rings as well
there not cheaper than accralights, MED are a distributer for omega iirc
yes stock 40 trim compressor .
Nick
Member #: 154
Midlands
just wondering what are the benefits from having forged pistons?
aside from the larger choices in dish size for us lot, how are they better than a cast piston?
I'm still running povo spec AE cast pistons @ 20psi with no issues other than wear, i'll be having a rebore at some point but can't see the point in spending double the ££ on a set of forged when i can get cast pistons with the dish size i need.
anyone care to enlighten me please?
which part no are they nick ? forged is more elastic ,and denser ,so take more of a beating from shock waves and seem to withstand greater heat .you can run a load of det on a forging without it breaking a land .
Nick
Member #: 154
Midlands
I'm running 21253's at the minute dished out to 11cc but i know you can take them to 14cc.
that's some food for thought then in favour of forged. i guess they're main advatage then is being able to tolerate a slightly bad setup?
So long as you don't use the minispares cast pistons, it appears you'll be fine. I don't ever recall anyone breaking the stock metro turbo pistons, even with ridiculous HP
We shall see*tongue*
pulse
Member #: 2011
so are we saying that the Cast Omega Pistons are man enough for the job? or ae the Forged pistons a well investment?
whose engine used them with rediculous bhp dave ,and how much boost and bhp was it :?
Nick
Member #: 154
Midlands
i've killed std metro turbo pistons..thankfully i've only done it once though..
the AE's have been spot on so far, fingers crossed.
*oh well*
Yo-Han
Member #: 3228
North of the Netherlands
Nick, I have a set of 21253's and am thinking of dishing them out.
Would you be willing to share how you did your set?
Would be greatly appreciated,
Han
Dazed and Confused....
Fast Carl (Force Racing) offers a piston dishing service:
http://www.force-racing.co.uk/machining-services/
Nick
Member #: 154
Midlands
i bought mine already done from simon @ morspeed
