Home > Help Needed / General Tech Chat > feed & return oil feed
battleroc
Member #: 5620
Dunstable, Bedfordshire
I'm doing a turbo conversion, what is a good place for oil feed and return on the turbo, for feed i was looking tee off the oil filter to block pipe or the oil pressure switch.
for the return at the mechanical fuel pump blank or the dizzy blank (as the car is running megajolt)
Oil feed usually tees off the oil pressure switch. And if your turbo is being mounted at the back of the engine, just use the hole in the back of the block where the mechanical fuel pump used to be.
battleroc
Member #: 5620
cheers for quick reply
the turbo will be clutch mounted you see
Ah ok, I'd return the oil back through the breather on the transfer housing.
battleroc
Member #: 5620
Cheers matty that's cool of you :)
I am just converting my spi to turbo you see and learning lots of things on the way
what engine you running?
battleroc
Member #: 5620
I was just thinking......... for the return could I use the dizzy hole to feed back into, as I may use it if the transfer breather hole is hard to get to when the turbo is on clutch housing.
would this be OK for a return?
yep back into the dizzy will be fine as long as you can get the pipework to fit ok.
wintersurferuk
Member #: 2208
im doing the same thing, into the dizzy cap, the oil drain on mine is to low for the transfer, theres some photos some where of it.... if not, i'll get some at the weekend.
pop some pics up of your progress :)
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=327942
mini_john
Member #: 731
is it ok to drain the oil back down a breather, would it not cause 'breathing' issues?
Im using mine with no problems, but I have also added extra breathers. The mechanical fuel pump location is a good place to run a pipe off into a catch tank.
Im running a turbo'd k1100 head. My build thread is on here, and it has some pics of my modified oil breather, quite simple really.
Edited by matty on 5th Feb, 2010.
