| Home > General Chat > Plug leads | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
5th Feb, 2010 at 08:54:37am
As I am sure many of you have done, I've got a megajolts which I currently am using a ford set of plug leads. They done fit very well and are to long for my current coil pack mounting place. Where can I get GOOD leads made up? Idealy with the elbow type connection one end and the ford coil pack ends the other?
784 Posts Member #: 912 Post Whore North Yorkshire |
5th Feb, 2010 at 09:23:35am
http://www.canems.co.uk/catalog/index.php?...347076a85cd9405
I drill holes in everything..! |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
5th Feb, 2010 at 10:38:10am
Wow, what an awesome find! can have the perfect leads made up, and a fairly sensible price too! Edited by Prawn on 5th Feb, 2010. Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
5th Feb, 2010 at 10:48:21am
I thought about getting a few made, on a different note can that boost control solenoid be used with MJ? |
5th Feb, 2010 at 01:20:46pm
I bought some ends and shortened mine down, I have the link for the bits at home, i'll dig it out tonight. On 28th Aug, 2011 Kean said:
5th Feb, 2010 at 04:54:24pm
here we go, I used the right angle boot and connectors right at the bottom of this page, last two items.
5th Feb, 2010 at 07:01:44pm
On 5th Feb, 2010 Si P said:
http://www.canems.co.uk/catalog/index.php?main_page=index&cPath=4&zenid=6f435a5df48b38f58347076a85cd9405 Got mine for these guys. Perfect and fast delivery too. Si Got mine from the same place thanks to si, spot on . Rick |
5th Feb, 2010 at 07:06:34pm
I got some fester ones of ebay for about £6. Perfect length for the mini or metro. How well they will work is another mater On 11th Feb, 2015 robert said:
5th Feb, 2010 at 07:43:08pm
I use the Bosh set 805 I think I will check in the garage. there small and a great fit with the original type of coil pack that has the clip on leads. I run a supercharger and I don't care the TB is on the wrong side.
155 Posts Member #: 246 Advanced Member Cumbria |
7th Feb, 2010 at 06:31:32pm
Just shorten your own , its easy ( and cheaper )
7th Feb, 2010 at 09:59:57pm
This thread couldn't have come at a better time, I need some Ford stylee leads but with a 90 degree plug end. I think I'll mod mine, is it hard to crimp on new ends? Thanks for the link guys. On 7th Nov, 2008 Nic said:
7th Feb, 2010 at 10:06:45pm
its easy,
7th Feb, 2010 at 11:12:12pm
Excellent, nice cheap mod too. Thanks for the info! On 7th Nov, 2008 Nic said:
8th Feb, 2010 at 08:27:19am
I have a set of magnicore, and there not very old and there are now shorting out on some thing if metal touches them , so not very impressed, just thought i'd tell you. Best 1/4 mile 13.2 seconds @116 mph
8th Feb, 2010 at 07:17:42pm
On 5th Feb, 2010 mini13 said:
here we go, I used the right angle boot and connectors right at the bottom of this page, last two items. http://shop1.actinicexpress.co.uk/shops/pa...gs__Honda_coils Ha! Didn't notice these guys were from Northern Ireland! Still cheaper to post than to go and fetch. Mr mini13, will a standard wire crimper be man enough to crimp these? On 7th Nov, 2008 Nic said:
8th Feb, 2010 at 07:21:46pm
8th Feb, 2010 at 09:32:22pm
