| Home > Help Needed / General Tech Chat > Safe boost? | |||||||
37 Posts Member #: 8150 Member |
5th Feb, 2010 at 03:09:22pm
Hello everyone,
5th Feb, 2010 at 03:22:27pm
Is the gearbox/diff original? I wouldn't run anymore than 8psi... |
5th Feb, 2010 at 03:27:51pm
Well I believe that it is original to the engine yes.
5th Feb, 2010 at 03:37:43pm
Should be about 80 in 4th at 4500rpm so the final drive has probably been changed, if it was built for rallying it probably had the diff upgraded too (providing they had some common sense) all you can do is ask the previos owner or strip the engine/box. Welcome btw :) |
5th Feb, 2010 at 03:39:19pm
Sounds like its got a very short diff in it then. Or your speedo is under reading by quite a lot. If something is worth doing, it's worth doing half of. |
5th Feb, 2010 at 03:54:45pm
The speedo does under read a bit as I have gone past speed checkers doing 35 when doing under 30 on the speedo. So I don't know if this would mean it was under reading even more at higher speeds. Just spoke to the previous owner and he said it is the standard box.
5th Feb, 2010 at 04:03:47pm
Use a sat nav to check the speed, then you can work out what final drive you're running. But this won't determine what diff you have which is the important part!
5th Feb, 2010 at 04:08:47pm
Ok that's great advice thanks :) That's what I'll do. Is there any way I can find out what diff is in it becuase it doesn't sound like the original owner knows it might not be standard?
5th Feb, 2010 at 04:10:08pm
