| Home > Help Needed / General Tech Chat > metro turbo piston rings | |||||||
![]() 673 Posts Member #: 1395 Post Whore chepstow |
11th Feb, 2010 at 12:46:58pm
"41570 ring set fits the 21253 S high compression pistons and the 22357 Turbo piston"
11th Feb, 2010 at 01:02:58pm
Not sure mate but you could buy these:-
11th Feb, 2010 at 01:26:22pm
No they don't the rings are 0.0591" on the 21253 with 0.1181" oil control ring and on the turbo they were 0.0625" and 0.1575" . You need R33646-00. |
11th Feb, 2010 at 01:28:47pm
Think I will bid on them and get total seal to make another set up. Thanks for the replys. Min-its are the ones who said that btw... |
11th Feb, 2010 at 01:35:25pm
£80 LOL http://www.minispares.com/Product.aspx?ty=...29&title=PISTON RINGS TURBO STANDA... |
11th Feb, 2010 at 02:35:48pm
On 11th Feb, 2010 gavin@minispares.com said:
£80 LOL http://www.minispares.com/Product.aspx?ty=...29&title=PISTON RINGS TURBO STANDA... Are they turbo rings?
11th Feb, 2010 at 02:40:15pm
Er yep |
11th Feb, 2010 at 02:49:12pm
Are they one set or 4 Gav? If something is worth doing, it's worth doing half of. |
11th Feb, 2010 at 02:55:26pm
I thought they were NLA |
11th Feb, 2010 at 03:17:26pm
One engine set :) will have to check availability as we only have 2 sets left in stock. |
11th Feb, 2010 at 03:25:23pm
Bit of a confusing descriptoon on that one Gav. It's tittle says Turbo pistons rings, but the description waffles on about +40 megas. On 11th Feb, 2015 robert said:
11th Feb, 2010 at 04:48:58pm
The description also says that they are for standard Mini and Metro 1275 pistons, which are not Metro Turbo Pistons.
11th Feb, 2010 at 05:15:32pm
Depends how you read it, i read it as meaning standard size for mini and metro turbo not for all 1275 mini's that would be silly. I'll change the description though as it is a bit pap :) |
12th Feb, 2010 at 10:44:30am
On 11th Feb, 2010 Sprocket said:
I have just taken delivery of my new Gapless Total Seal rings for the Turbo pistons at a cost of £105 delivered. I have no problems with paying that much after seeing how much less blowby these rings have compared with similar engine builds :) Did you send them the specs for the rings? |
12th Feb, 2010 at 06:18:35pm
I have just taken delivery of my new Gapless Total Seal rings for the Turbo pistons at a cost of £105 delivered. I have no problems with paying that much after seeing how much less blowby these rings have compared with similar engine builds :) Did you send them the specs for the rings? They are a catalogue item!! :) On 26th Oct, 2004 TurboDave16v said:
