| Home > Help Needed / General Tech Chat > Remote Gearbox.. | |||||||
13th Feb, 2010 at 07:23:54pm
A quick question for those A series experts.
13th Feb, 2010 at 07:28:55pm
I always shim this item quite tightly, but remember, that it does need to move. On 13th Jul, 2012 Ben H said:
13th Feb, 2010 at 07:46:59pm
Vegard, I presume wear in these components doesn't help with gear change? I run a supercharger and I don't care the TB is on the wrong side.
13th Feb, 2010 at 11:44:02pm
On 13th Feb, 2010 gr4h4m said:
Vegard, I presume wear in these components doesn't help with gear change? Of course not. The problem is that the shafts wear, not the easy to change bushes. OS bushes cannot be used as there are splines on the ends of the two long shafts. I searched and found some good ones, the other options is to have metal sprayed on and milled down in a lathe. If there are no regulations, I see no use for a remote change box apart from originality. On 13th Jul, 2012 Ben H said:
14th Feb, 2010 at 12:06:02am
I was thinking the same... and you cant swap the cases either. I have a couple of spare remote boxes that I started to collect as I realise it old stuff now and people in the local club were chucking out. I will check the shafts and see what has the least wear.
Edited by gr4h4m on 14th Feb, 2010. I run a supercharger and I don't care the TB is on the wrong side.
14th Feb, 2010 at 12:22:05am
I like the remote box purely for the extra engine steadying, I seem to be able to kill steady bushes fairly quickly on rod boxes... On 28th Aug, 2011 Kean said:
14th Feb, 2010 at 12:24:03am
On 14th Feb, 2010 mini13 said:
I like the remote box purely for the extra engine steadying, I seem to be able to kill steady bushes fairly quickly on rod boxes... You've got a valid point, but I'd rather have the rod box and a bunch of engine steadies. On 13th Jul, 2012 Ben H said:
14th Feb, 2010 at 12:34:20am
even with 4 steadies i still seem to be able to wrench the lump loose :/
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
15th Feb, 2010 at 02:26:45am
My remote has huge amounts of wear, about 3-4 mm sideways movement in the selector.
In boost we trust |
15th Feb, 2010 at 08:51:47am
On 15th Feb, 2010 best_stig said:
My remote has huge amounts of wear, about 3-4 mm sideways movement in the selector. The gearstick moved a lot but i could still find gears (no one else could though :)) This is of help: https://secure.surfinteractive.co.uk/cgi-bi...iParts:MiniMisc I've got one in my race-car. On 13th Jul, 2012 Ben H said:
