| Home > General Chat > DIY Air Flue Ratio Meter | |||||||
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
13th Feb, 2010 at 08:35:59pm
I don't really have the cash to splash on a fancy gauge, so something being better than nothing i am going to have a bash at making my own.
857 Posts Member #: 1778 Post Whore Northants |
13th Feb, 2010 at 08:53:53pm
Someone posted up recently some links to a cheap wideband solution with a display.
13th Feb, 2010 at 09:09:11pm
mac , you can do it a bit cheaper , get a digital voltmeter ,and just read off the black wire in millivolts .anything nr 1 volt is richer than 14.7, anything lower than 500 mv will be in the leaner than 14.7 area .
Edited by robert on 13th Feb, 2010. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
207 Posts Member #: 193 Senior Member Aylesbury |
13th Feb, 2010 at 09:24:06pm
13th Feb, 2010 at 09:56:40pm
Sturgeo, i did come across that thread and it seams the conclusion robert came to is the link at the bottom is the cheapest. Dose a wide band sensor work the same way as a narrow? kicking out between 0-1v? if so i could use one of these with the same meter.
14th Feb, 2010 at 07:05:14am
On 13th Feb, 2010 maccamcvey said:
Dose a wide band sensor work the same way as a narrow? kicking out between 0-1v? if so i could use one of these with the same meter. Sadly life is not that simple, wideband & narrow band sensors are very different beasts, I think Sprocket posted how wideband sensor work a few years back, but in short the wideband sensors do not produce a 0v - 5v linear output. Isambard Kingdom Brunel said:
14th Feb, 2010 at 07:28:44am
luke ,the narrow band sensor is a little like a switch ,anything a bit richer than 14:1 or leaner than 15:1wont change the voltage much,.
14th Feb, 2010 at 09:25:22am
The output from a wideband system is typically 0-5v, but this is conditioned and can be set to what you like. As for how to condition it I have no idea.
http://www.twin-turbo.co.uk
14th Feb, 2010 at 10:20:18am
that lambda from a rover is a narrow band, ive been replacing the one on my other car, i presumed it was a wideband, but it appears it isnt
Edited by Nic on 14th Feb, 2010. |
14th Feb, 2010 at 10:41:40am
The wideband sensor needs some sophisticated electronics to get a 0-5v signal. The sensor alone will not do that.
14th Feb, 2010 at 10:42:32am
On 14th Feb, 2010 Ben H said:
am a bit nervous about using the wideband on a carb'd car. What is the risk, can it kill the sensor? It will be fine. I used twin widebands with a carb for a while. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
14th Feb, 2010 at 11:40:25pm
Try www.14point7.com 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Feb, 2010 at 06:55:27pm
top link cheers mike, may have a bash :) |
66 Posts Member #: 8258 Advanced Member |
16th Feb, 2010 at 09:04:29am
Hi, why don't you call David Hampshire @ Canems Engine Management Solutions 01724 331688 or 07903 396294 & ask him about the stuff you require.
