| Home > Help Needed / General Tech Chat > MINI supercharger + 998? | |||||||
29 Posts Member #: 230 Member |
14th Jan, 2005 at 04:27:07pm
is it possible to use a bini supercharger on a 998 engine? can anyone see any problems with it? |
![]() 281 Posts Member #: 441 Senior Member |
14th Jan, 2005 at 05:05:29pm
yeah anythings possible,ive already asked stuart as i wanted to get the misses's 998 done, he said its possible probably talkin 90bhp tops on a stage 1 mini,decent head.but not worth it when you can get a cheap 1275 and get over 100bhp... (his words) which is true |
14th Jan, 2005 at 08:38:26pm
i guess but its something different isn't it. its far more simpler to just drop a standard 1275 in and do a few mods but its not much of a challenge and not much of a talking point when you open the bonnet! i think i may still be heading the way of a 998sc
Edited by ccharlie6 on 14th Jan, 2005. |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
15th Jan, 2005 at 05:15:28pm
750cc pass, same as a shorrock. Should be fine, unless you get low speed passing, which I don't think you do. It is harder than it looks to do it yourself. Bugger off, I'm getting there. |
15th Jan, 2005 at 06:37:52pm
i thought it would be quite a hard job to do which is why i was wondering if the Vmax kit could be adapted. same love_machine as pistonheads??? hows your kit going |
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
17th Jan, 2005 at 11:14:08am
hi,
17th Jan, 2005 at 07:12:04pm
that sounds really good. will i need to build my engine with low comp pistons aswell though? as im running flat tops at the moment |
17th Jan, 2005 at 08:43:01pm
I'd have thought you'd be best sourcing a 12G295 (?) head - as fitted to the 998 coopers. These have a massive chamber volume, as the 998 cooper motor had 'raised' pistons.
17th Jan, 2005 at 10:44:07pm
low comp pistons not ness, but if your pistons are dished i can mod the head to suit either , you will need a suitable fuel system capable of supplying enough fuel though |
