Home > Wanted > Thin Driveshafts
powcomnaj
Member #: 7860
Hereford
I'm looking for a pair of thin driveshafts for a mk2 i'm rebuilding as standerd, they are about half as thick as 1275 driveshafts and are mostly fitted in drum
Anyone able to help??
This is not true. Driveshafts are the same, apart from early Cooper S.
and one other vegard......*wink*
Really? I'm postive i have seen these thin shafts,
powcomnaj
Member #: 7860
Hereford
Not cooper s were on 850 & 1000 with drums, I've got one here i found on an B reg city with heavy front damages, I'll take a pic nice to a thick one!!
Adam_R
Member #: 1938
near Dundee
ive got a few drum setups i shall have a look and compare to my discs setup
Me too and I'm intrigued....
998 with disks (c85) are just over 25mm (so probably 1")
998 with drums (c81) are exactly the same.
998 with drums (c71) are just under 23mm (so probably 7/8")
Note the '71 shafts are the sliding joint, rubber cross coupling type, not for pot joints.
Is that what you meant by Mk2 ???
I've only ever seen these thin shafts on pot joint cars, seemed to be the economy biased cars with long final drives. Why they are thinner I have no idea.
Asphalt
Member #: 1027
Germini, black forrest
They were fitted to (some!?) drum brake cars in the very late 70's to early/mid 80's. As far as I know:
Thin shaft / std. late shaft.
Thin: 18,3mm dia,
Std: ~25mm dia (didn't clean it to measure)
@Tom Fenton:
My car (early-ish 1984) was originaly equiped with a 2,95 diff & thin drive shafts! Sounds plausible :)
Jan
Edited by Asphalt on 14th Feb, 2010.
[X] nail here for new monitor
powcomnaj
Member #: 7860
Hereford
Thanks Asphalt, you saved me putting a picture up!! *smiley*
I've got no problem being correctified, but that's a new one to me...
So, the only sane thing to do is to fit a thick long one and a short thin one to correct torque steer.
More to the point, how much lighter are they? lol
Asphalt
Member #: 1027
I didn't weight them with a scale; but considerably lighter :)
Would there not be an increased risk of snapping these?
Asphalt
Member #: 1027
I think the weakest point is where the circlip sits anyway... :) Or am I wrong? :)
they are a new one on me also,
but a plus point may be at launch on the strip, you could get some serious twist much like a wrinkle wall tyre ,thus a shock less take up of tyre on tarmac,
now i just know wiggies going to be scratting around all the junk yards in MK for a set or three,lol
Would it be out of the question to turn a thick set down?
yes . they are kind of case hardened .
What this actually means is that Carl has tried to do this.
MrTurbo
Member #: 814
Utrecht, The Netherlands
...*wink*
what Tom is refering to is the time i parted a shaft off to sleeve and lengthen for some chap, as i suspected it was harder/tougher on the skin than the core, this was backed up by my trying to eat some of the outer layer, it was very hard to bite a decent size piece off, but i could nibble away at the core with no bother,
Somehow that just sounds bad and wrong Carl.
Ti teeth aren't up to the job then?
