Home > Help Needed / General Tech Chat > basic non dead engine check
masterchief
Member #: 7308
Devon
hi all
its just a quick one, ive bought a clean lookin engine today but the guy is a little unsure on condition of it but thinks it should run ok with no problems, now is there anything i can do without stripping to motor down to see what condition its like? it does turn over freely and like i said its complete and it does look painted and not grimey
any help will be great
Nick
Member #: 154
Midlands
hook up a battery to the starter and a comp tester is about all really?
do one run with a compression tester write down the figures they should all be near the same 165 160 165 160 for example then another after with a little squirt of oil in the bore and see what the difference is if its massive then there is a problem with the rings *wink*
MONSTER HEDGEHOG
Member #: 4340
sideways, Birmingham
id do all of the above and then a bench test, it saves you fiting it in the car and then finding out its FUBAR
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol
carl
FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR"
also whack a oil pressure gauge on,
if its shite with a cold engine theres obiously an issue
