Home > General Chat > what piston is this
azzer
Member #: 7467
do eneyone now what piston this is 20142 f49 1d4 i was tlod is was a turbo piston but not sure ???????????
is it 1275 or 1293
Its a hepolite piston and i recon its a standard size, however, the Hepolite power max 73.5mm piston is classed as a standard size, but I am not sure of the part number.
Measure the bore to be sure if its 70.61mm, or 73.5mm
my 73.5 powermax's have 20659A on them
Well ther you are then, its a standard size 70.61mm piston :)
How many rings does it have, its more three, its not ideal
