Home > Help Needed / General Tech Chat > How many teeth down to set timing to?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
hi, when i get my mini back i want to do the timing straight away, going to get it rolling roaded next week its booked, in but i need ot use it in the mean time.
when doing it, how many teeth down should the white line be when it flashes? Is it 7degrees (think thats 3&1/2 teeth) like on my old 998cc?
Thanks
james
Carl
Member #: 95
liverpool-on-sea
the rollin road guy will need to adjust it anyway so you may as well leave it
each one of those teeth is 4degrees, so slighlty before the second tooth
jamesfawcett
Member #: 218
justot make sure, thats the second tooth down isnt it, the top one is the first? you dont do it from the bottom or anything? Sorry for all the questions they must be silly to you :(
yes thats it, not at all silly, i only just learnt how to do it and i was amazed how easy it was,
actually first would be 0, second down would be 4, and third down would be 8
sorry about that, i think im right, but if it goes pop its not my fault! try it and see, adjust it and if its not right adjust somemore
jamesfawcett
Member #: 218
ok i did it, i used a long thin screw driver and got the piston to the top.
I marked this position on the flywheel(?) next to hte teeth iwth tippex and a nice thin line and hooked up the timing light it was quite a bit out.
I tell you what, im AMAZED now at the difference, i set it to slightly before the second tooth down and it was idling perfectly at 700prm. Its driving like a new car its really smooth and a hell of alot quicker even though its only at 4psi!
