Home > Wanted > Off Cut of Roll Cage Tube
I'm after an off cut of 40mm OD roll cage tube about 200mm - 300mm long to make a steering column bracket if anyone's got any going spare?
Annoyingly I've got offcuts of 1 1/2" (~38mm) and 1 3/4" (~44mm) but as I need to fit idler bearings inside the tube the inside diameter needs to be between 34mm & 35mm (I can fine tune it on the lathe).
Rob
i'l have a look later on
Did you find any?
sorry rob it all went out with the scrap last week,
