Home > General Chat > Some techno stuff
Advantage
Member #: 1450
Near Paris - France
http://www.youtube.com/watch?v=Rz9t1u5F6Uo
Check out the cams : narrowed where they do not lift.
Every little helps ...
Rusty by nature
wont go very far they forgot the clutch
Anyone seen the con rods from some of the latest small car petrol engines?
The main beam is triangular with nothing in the middle and the big end cap was originaly part of the whole rod, which has then been fractured off, thus reducing machining processes. Trick stuff!!
Edited by Sprocket on 16th Feb, 2010.
Advantage
Member #: 1450
Near Paris - France
I didn't but I have seen the new Insight crankshaft arrangement and the 5 caps are actually connected in a single part : must be stiffy !
Rusty by nature
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
I did see cracked rods on some small VAG engine. Could have been a 1.4 or 1.6
On 30th Apr, 2010 Rod S said:
Gary's description is best
my 1995 astra rods are like that .
The modern Jaguar V8 engines have also got this "fractured" big end rods. I guess they can do it as the sintered rods are very hard and brittle. Makes honing them a bitch though *wink*
mondeo desils are fractured like that too.
They are still made from forged steel, it is a special steel that is fracture split, and does so along the grain structure, meaning it splits and fits back together perfectly.
Where I work we make this grade of steel for various OE manufacturers, we call it "Fractim".
It makes a cost saving, as the rod can be bored to size, bolt holes drilled and faced, and then split. No more machining operations required.
Edited by Tom Fenton on 17th Feb, 2010.
evolotion
Member #: 83
Glasgow, Scotland
yip seen the hollow conrods and hollow crankshafts on 1.2 16v vauxhall engines look soo weedy!
Denis O'Brien.
evolotion
Member #: 83
Glasgow, Scotland
the narrowed off-lobe camshafts i have seen before too, but the off lobe bit was offset i assume to promote spin in the follower, canny mind what engien it was though..
Denis O'Brien.
