Home > General Chat > how much waxoil into a mini?
welshdan
Member #: 1111
s wales
its getting to a point where i needed to waxoil my mini before assembling certain parts of trim. the waxoil was setting in the gun as i was squirting it (kept the cannister in a bucket of hot water)
so decided to waxoil the car with a piece of hose and a 50 ml syring (yes i know!)
i ended up taking a good few hours, but used the best part of 8 litres *surprised*
surely this isnt normal? i masked up the sill vents, when i took the masking off and stuck my finger in there it seems the sills are now solid filled with waxoil. not ideal i know, but when it warms up it should start to drip out!
also drilled from the inside of the car to the area under the front scuttle corners and waoiled them. its all fresh metal there so thought i better had. then blocked it off again with a small gromet.
clubminiflip
Member #: 54
nr coventry
i usually put the tin on a low heat on a little camping stove! works a treat
i've put about 10 litres of waxoyl in my mini! but i'm a bit overkill
you can brush it on the areas you have access too!
anther method is leave a heatgun/paitstripping gun on a low heat facing the can!
it keeps the wax from setting & works well!
thats what i doanyhoo
welshdan
Member #: 1111
s wales
it was setting pretty much as it hit the metal.as i said it was a bit cold but it was getting to a point that i would have to stop work on the car and wait til the weather warmed up before i could do anything else
yes it's normal i used 4 or 5, 5 litre cans on mine.
welshdan
Member #: 1111
s wales
did you do underneath/outside? only did the interior of mine. guess it looks messy when all of the crap from the road sticks to it
EVERY where mate, that's why i used so much, any place that wasn't painted.
welshdan
Member #: 1111
s wales
fair enough! i think i got all the unpainted parts on mine too...
Nice one, hope it does the trick for use both then *happy*
clubminiflip
Member #: 54
nr coventry
yep inside/outside/underside! dont forget to all the box sections like the crossmemeber sills, scuttle panels which can be acccessed from the ending bay,
feel around youl find the hole LOL
everywhere you can squirt that stuff
i sound like a right pervert!
dont worry about it going hard in the cold we have at the moment, it'll dribble down all the surfaces when the weather warms up,
either way your giving it the protection it needs
