| Home > Help Needed / General Tech Chat > Mayo in cap, but head gaskets ok ? | |||||||
15th Jan, 2005 at 06:01:58pm
Made it home from glasgow, just! broke down at two roundabouts i think just down to the tuning being really poor. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
15th Jan, 2005 at 06:34:58pm
its from using the car for many short journeys where the engine doesnt get chance to warm up properly
15th Jan, 2005 at 06:49:04pm
totally agree, make sure you have a hot thermo stat at least a 82 deg with out any holes in, and keep the heater tap open for cuirculation.
15th Jan, 2005 at 11:11:05pm
Yep i have the same problem and i've found if i cover the oil cooler with foil it helps loads...
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
![]() 1014 Posts Member #: 238 Post Whore essex |
16th Jan, 2005 at 11:31:40am
yep mine still does this? head gasket has been changed, oil has been changed twice! and still i get mayo in the cap?
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
16th Jan, 2005 at 03:49:11pm
you got to make sure you get your engine and oil hot enough. this drives of both moisture and hydrocarbons from your oil.
16th Jan, 2005 at 05:24:07pm
Thats great advice, ill use a bypass pipe for my oil cooler for the time being Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
17th Jan, 2005 at 07:09:23pm
yep you shouldnt need a oil cooler in this weather, try fiiting a oil temp sender as well to give accurate oil temp readings, most people would be suprised how long oil temp even in a turbo car takes to heat up.
