| Home > General Chat > Re Shell ????? | |||||||
18 Posts Member #: 8199 Member |
18th Feb, 2010 at 10:10:34pm
If I Was To Have A Rotten Classic Cooper And A Good Solid Sprite Shell Would It Be Possible To Transfer The Tags Legaly To Use The Good Shell But With The Old Running Gear ??? Thanks |
18th Feb, 2010 at 10:15:32pm
Probably not legal, but no one needs to know On 7th Oct, 2010 5haneJ said:
![]() 395 Posts Member #: 3636 Senior Member herefordshire |
18th Feb, 2010 at 10:17:39pm
should be fine, but dont do what some people do and put mk1 plates on a mk4 that doesnt even have a mk1 grill :L |
18th Feb, 2010 at 10:31:35pm
I think re-shelling is legal providing you keep and certain amount of parts from the original car.
Edited by Rob H on 18th Feb, 2010. Isambard Kingdom Brunel said:
18th Feb, 2010 at 10:43:29pm
Think it has to be a new shell from the factory to use the same same chassis number. On 19th Jan, 2010 wil_h said:
18th Feb, 2010 at 10:52:31pm
chassis numbers are stamped into the scuttle on later cars, i believe jason is right legally you can only reshell into a new shell
18th Feb, 2010 at 11:04:28pm
Not sure on the 'Q' plate laws..but if you have a shell with no numbers, lost etc...but can prove the year of manufacture, can you get a age related plate? On 19th Jan, 2010 wil_h said:
![]() 54 Posts Member #: 5639 Advanced Member Weert Holland |
19th Feb, 2010 at 01:01:01am
Mines in a different shell documents are 1983, shel is a donor 1991 shell.
Edited by Andrew 998 mini on 19th Feb, 2010. Cheers, Andrew
19th Feb, 2010 at 08:58:37am
What do you call a 'classic Cooper'? A mk1 or2?
I seriously doubt it! |
19th Feb, 2010 at 09:26:31am
I think in the past it was common practice to do such things. But it is frowned upon these days. And the DVLA have properly clamped down
