| Home > Help Needed / General Tech Chat > possible camber/castor toe in/out settings | |||||||
![]() 54 Posts Member #: 5639 Advanced Member Weert Holland |
19th Feb, 2010 at 12:55:31am
Hi peeps,
Cheers, Andrew
280 Posts Member #: 4340 Senior Member sideways, Birmingham |
19th Feb, 2010 at 01:22:00am
my fronts are 3 degrees negative canber and about 4 degrees posivive caster, i cant remember what my KPI was but it was about right for a mini even with the metro hubs fitted which was wiered,
On 15th Dec, 2009 fastcarl said:
sell the lot to me for £70 pounds and i'll let you stand on the outside edge and look on my inner circle of closest frinds, lol carl FOR EVERY WELL THOUGHT OUT AND WELL EXECUTED PRICISION JOB EVER CONCIEVED, YOU CAN GUARANTEE THAT SOMEWHERE IN WALSALL OR THE BLACK COUNTRY THERE WILL BE A BLOKE TRYING TO ACHIVE THE SAME BY MEANS OF "ITIN IT WI LUMP AMAR" |
19th Feb, 2010 at 07:39:18am
As will beome apparent in all setup threads there is much conflicting opinion.
19th Feb, 2010 at 04:57:07pm
front ,1.5 neg camber ,...4 degrees caster... 1mm toe in .
19th Feb, 2010 at 05:52:20pm
Robert, why would you run toe in at the front? On 13th Jul, 2012 Ben H said:
19th Feb, 2010 at 06:32:58pm
so my feet are closer to the brake pedal. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Feb, 2010 at 06:34:52pm
On 19th Feb, 2010 robert said:
so my feet are closer to the brake pedal. Ha ha, great response! On 7th Oct, 2010 5haneJ said:
19th Feb, 2010 at 10:40:07pm
Thanks, this is starting to be a good list of peoples possible setups, Keep it coming.
Cheers, Andrew
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
20th Feb, 2010 at 03:10:41pm
10" x 5.5"
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
20th Feb, 2010 at 10:53:57pm
10" x 4,5 and 10" x 5, R32´s
internationally known as "big" swede |
21st Feb, 2010 at 01:24:06am
Thanks to all, this is great, but have a question, does the 3 + degrees of front camber not compleatly chew the front tires??
Cheers, Andrew
