Home > Help Needed / General Tech Chat > Step washers??
1293 sprite
Member #: 5449
Melton Mowbray
Hi
I finished building my engine on thursday on a day off, so trial fitted the maniflods and carb onto it.
The problem I got was that the inlet manifold flanges were thinner than the metro exhaust manifold flanges, so when the nuts were fully tight the big washers didn't touch the inlet manifold, so it was loose. there was about a 3-4 mm gap between the inlet manifold and the head.
Whats the easiest fix for this please? I was thinking either cut down the exhaust manifold to match the inlet manifold, or get hold of some special washers if they exist?
Thanks
James
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
Cut some washers up and tack them to the thicker washers
Nick
Member #: 154
Midlands
have the exhaust manifold machined down, at least this way you'll know it'll be dead flat and won't have to worry about it being slightly warped.
wished i'd done mine this time but i keep forgetting about it till i come to do the nuts up.
1293 sprite
Member #: 5449
Melton Mowbray
Thanks for the help lads. I'll get it done.
17.3 1/4 @ 78 mph
