| Home > General Chat > OT - Help with LM317 voltage regulating circuit | |||||||
21st Feb, 2010 at 10:41:17am
I'm trying to create a stable power supply for use inside my camper van, I've bought some LM317, and I've wired them up like this:
21st Feb, 2010 at 10:42:05am
This is the info I used : http://www.reuk.co.uk/LM317-Voltage-Calculator.htm
21st Feb, 2010 at 10:58:17am
That information is a little confusing and perhaps missleading?
Edited by Sprocket on 21st Feb, 2010. On 26th Oct, 2004 TurboDave16v said:
21st Feb, 2010 at 11:14:55am
http://www.national.com/ds/LM/LM117.pdf
21st Feb, 2010 at 11:32:49am
What Colin is getting at is with a reg such as the 317 the highest voltage you can get out is about 1.5v lower than the input voltage,
21st Feb, 2010 at 12:40:00pm
That would be really handy, this is mainly for my diesel heater, (which so far I've blown up two ECU's due to crappy voltage spikes) so it will need to able to supply 10amp peak. How many would I need? On 15th May, 2009 TurboDave said:
21st Feb, 2010 at 10:45:02pm
If money isnt an issue, you can buy proper voltage regulators/boosters/whatever.
21st Feb, 2010 at 11:42:22pm
if its power spikes surely a capacitor, Metal oxide varistor, avalance, zener doide sircuit would be more suitable? couple that with a regulator and ought to be nigh on bullet proof.
24th Feb, 2010 at 05:54:08pm
Jim, what ecu are you killing with spikes?
24th Feb, 2010 at 05:56:02pm
it is for my eberspacher diesel night heater, just trying to make sure it gets clean power really On 15th May, 2009 TurboDave said:
244 Posts Member #: 34 Senior Member |
24th Feb, 2010 at 07:37:09pm
The eberspacher is designed for cars boats etc so shouldn't require any additional filtering.
24th Feb, 2010 at 08:37:03pm
The heater is in my camper /race transporter.
24th Feb, 2010 at 09:21:37pm
On 24th Feb, 2010 Jimster said:
but I'm thinking of removing the mains earch from the van, any thoughts? A very bad idea unless you install an isolating transformer with its own independant earth on the secondary side. The earthing on mains is to protect you, as 240v can kill. Equipment that is earthed will blow a fuse if a fault occurs, without the earth, you are the fuse. Schrödinger's cat - so which one am I ??? |
24th Feb, 2010 at 09:47:50pm
Yeah don't remove the earth!
24th Feb, 2010 at 10:41:16pm
When I killled the eberspacher ECU's did have the power feed for the heater going directly to the batteries (with fuses).
Edited by Jimster on 24th Feb, 2010. On 15th May, 2009 TurboDave said:
25th Feb, 2010 at 09:06:59am
yep, from live to ground.
