| Home > Help Needed / General Tech Chat > Meziere Pump Mounting | |||||||
21st Feb, 2010 at 06:47:40pm
Just a quick question. I will be mounting my WP136S soon. The info with the pump doesn't mention anything about how to mount it. I want to put it on the subframe or rad bracket where the old rad was. Do I need to mount it through rubber mounts or can I solid mount it onto something like the subframe?
Gary's description is best |
21st Feb, 2010 at 07:13:19pm
i just drilled 2 holes on the side of the subframe where it has a lip going up and bolted it through there, no rubber mounts |
21st Feb, 2010 at 07:15:11pm
Excellent, thanks for that Nic. I'll do something similar On 12th Nov, 2009 Paul S said:
21st Feb, 2010 at 07:50:35pm
I made some fancy nancy ally bracket made up and then bent it whist removing my engine! lol
21st Feb, 2010 at 07:58:29pm
Cheers Matty. Whatever I make would probably look better after it gets bent to shit On 12th Nov, 2009 Paul S said:
264 Posts Member #: 11029 Senior Member Crewe |
30th Mar, 2020 at 04:39:17pm
Is 10 years a good time to re-open a thread ?
Outside the box |
30th Mar, 2020 at 07:51:27pm
Mine is on all the time, however knowing what I know now this may not be the most efficient way to do it.
30th Mar, 2020 at 11:15:02pm
GaryOs, whatever happened to him ? Lol
31st Mar, 2020 at 09:15:00am
I run mine on all the time.
My build thread..
31st Mar, 2020 at 06:36:33pm
i was contemplating using the Davies Craig controller with it however i think i am going to run it with a 82 degree stat plumb the heater outlet to the turbo then heater to thermostat housing as the bypass i have it dry decked and have an Audi 80 radiator to front mount inside the bmw intercooler in the front of my clubby estate. i'm at the point where i'm ready to drop the engine in and make all the pipework up but this bloody virus means i cant get to the car as were all in lockdown Edited by monsterob on 31st Mar, 2020. Outside the box |
31st Mar, 2020 at 06:48:45pm
I’m pretty sure you can’t use a stat with the electric pump ? Hence the use of the controller to regulate temperature.
31st Mar, 2020 at 06:57:12pm
from the reading i did last night (under the influence) as long as the pump is not pumping against a closed stat without a bypass which i proposed as the heater outlet on the head to turbo feed to heater and thermostat housing post stat the stat would still function as it should this coupled with a fan controller set as off at 85 degrees on at 95 should regulate it without the need for an expensive controller?
177 Posts Member #: 10990 Advanced Member Hornsea |
31st Mar, 2020 at 08:28:34pm
The controller works well for me, I like how the pump and fan runs on after switch off if the motor is still hot to help ease heat soak. And with the front mount rad it never goes over what ever temp I set the controller at even when used on track, which the car is mostly used for. |
31st Mar, 2020 at 08:45:48pm
Nice one Burcy. i met you at castle combe a few years ago with the crewes missiles you camped up with us.mine was the orange thing with the teeth that wouldnt keep fluids in the engine ! Thing is ive got the Mezeire pump as i didnt like the design of the davies craig ones but dont think anyone using this pump controls it in any other way than off and on. Outside the box |
31st Mar, 2020 at 09:50:15pm
Hi Rob,
31st Mar, 2020 at 10:00:31pm
That should be possible as they have many a user output but i'm not sure how confident i would be in my computing skills its not word excel or power point ...... Outside the box |
31st Mar, 2020 at 10:14:32pm
I have a thermostat, but it has a couple of extra holes in it so that it is not pumping against a closed circuit.
31st Mar, 2020 at 10:24:03pm
so would the suggestion be a stat with some extra holes to allow some flow past when
Outside the box |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
31st Mar, 2020 at 10:39:59pm
On 31st Mar, 2020 Nic said:
I have a thermostat, but it has a couple of extra holes in it so that it is not pumping against a closed circuit. If you have a bypass it will do the same, hopefully the turbo will be enough of a restriction so everything doesn’t go that way. Could the Davies Craig controller be used with this pump? Roy makes a good point, I have a heated rear window timer relay that always me to switch on the pump to leave it running after switch off |
1st Apr, 2020 at 09:34:53am
I just have mine wired up with a two step toggle switch. first step is water pump 2nd turns the fan on aswel. I just leave them on for a minute or two after I turn the engine off. it soon looses heat. it's good for the turbo aswel as it's water cooled. Edited by JT on 1st Apr, 2020. My build thread..
1st Apr, 2020 at 12:22:53pm
As per Nic's previous comment, one of these could be made to work very easily to provide run on for the pump.
Edited by shane on 1st Apr, 2020. |
