Home > General Chat > Gearbox Rebuild
i am looking to buy all the bits to build up a box, mainly from minispares
on the list
evo clubman gear set
straight cut drops 23/30/23 tooth
centre pickup
but im having trouble finding the bearing set what have you guys used for this setup? is it a case of buying them all separately
the bearing kit MSG22 includes parts i dont want, are the competition baulk rings really needed (c-22A1741) as there out of stock anyway
cheers
Any particular reason for going for the 23 tooth Primary and Input? They are supposed to be significantly noisier than the 24 tooth variants.
been advised by a couple people that they are stronger, thats about it realy :)
The minispares articles seem to indicate that but I doubt you would bust a 24 tooth item. I suppose if you aren't bothered about the noise it doesn't matter.
