| Home > Help Needed / General Tech Chat > no spark! | |||||||
289 Posts Member #: 8160 Senior Member , mitcham, surrey, london, cr4 |
23rd Feb, 2010 at 09:04:41pm
hi there!
Nothing special! |
23rd Feb, 2010 at 09:59:47pm
as far as i can recolect ........... i may be wrong but......... you need a live wire to the pos on the coil when the ignition is switched on then piggy back that live wire to the destrib on the top terminal then the bottom terminal goes to the neg on the coil if you want to use a taco piggy back off the neg on the coil
23rd Feb, 2010 at 10:24:23pm
do someone have wiring picture, diagram?
Nothing special! |
24th Feb, 2010 at 08:10:59am
what year is your car? you could have the ballasted ignition setup that only gives 9v unless cranking the starter. On 11th Feb, 2015 robert said:
24th Feb, 2010 at 08:57:15am
On 23rd Feb, 2010 chominsh said:
is there 1 wire from ignition to coil (+) Correct providing it a 12V feed (usually white) and not a ballast wire (usually pink/white) On 23rd Feb, 2010 chominsh said:
then (+) and (-) goes from coil to electric distributor. Correct but they MUST be the right way around or the electronic module is toast On 23rd Feb, 2010 chominsh said:
1 wire from body (-) to coil (-) NO, not to the body. There is no second wire to the coil -ve unless the car has a tacho, then it's a black/white wire to the tacho. Schrödinger's cat - so which one am I ??? |
26th Feb, 2010 at 01:26:59am
''what year is your car? you could have the ballasted ignition setup that only gives 9v unless cranking the starter.''
Nothing special! |
26th Feb, 2010 at 01:33:32am
1 wire from body (-) to coil (-) NO, not to the body. There is no second wire to the coil -ve unless the car has a tacho, then it's a black/white wire to the tacho. hi i have pink and white wire connected from ingnition to coil! so i have not ballasted ignition? is it can be the reason ??? if yes how i can chage it to ballasted?? how i can check if thid distributor is working at all?? maybe it was toasted before??? Nothing special! |
26th Feb, 2010 at 01:34:40am
sorry for my grammer Nothing special! |
26th Feb, 2010 at 07:38:17am
Pink/white is usually a ballast wire which is a special piece of resistance wire to drop the voltage down to 8-9Volts for a ballast type coil (which runs at a lower voltage and is fed direct from the starter solenoid when starting the car when the battery voltage is low).
Edited by Rod S on 26th Feb, 2010. Schrödinger's cat - so which one am I ??? |
28th Feb, 2010 at 05:32:18pm
mmm..
Nothing special! |
28th Feb, 2010 at 06:10:56pm
You need to make sure the positive wire is a 12V wire, not a ballast 8-9V wire.
28th Feb, 2010 at 06:34:19pm
On 28th Feb, 2010 Rod S said:
You need to make sure the positive wire is a 12V wire, not a ballast 8-9V wire. The colours usually give it away as the 12V wires are usually plain white and the 8-9V ballast wires are usually pink/white. But if you want to be sure use a DVM / multimeter / voltmeter / whatever else you want to call it.... You really can't trace electrical problems without one. And you don't need a "special" coil, just the one that belongs with the electronic dizzy. Lots of later Minis and Metros - carburettor versions - used the electronic dizzys. The originals coils that belonged with them are clearly marked. but if it is 8-9v ballast wire, so i need to replace it (from fuse box till coil) but where i can buy wire which will geive 12v? the previous owner sad that: ''the livegoes to ingnition live and minus goes to minus in the loom'' so (+) i need to connect with 12v wire which goes out of fuse box to (+)coil? what is loom? is it (-) of coil? thank you i wish i could understand more in electric
Nothing special! |
28th Feb, 2010 at 06:51:02pm
Any wire (of a suitable size, ie, like all the rest in the loom) will give you the 12V you need if connected between fusebox and coil.
28th Feb, 2010 at 06:55:26pm
so i need to look for non ballast coil? Nothing special! |
28th Feb, 2010 at 06:57:17pm
ok i will go to check, hope it will work :))))))))))))) Nothing special! |
28th Feb, 2010 at 07:03:57pm
On 28th Feb, 2010 chominsh said:
so i need to look for non ballast coil? You need the right coil that belongs with the electronic dizzy. There are other coils that will work but don't even think about it until you have the electronic dizzy working with the right coil..... Schrödinger's cat - so which one am I ??? |
28th Feb, 2010 at 07:20:52pm
yea, but how i can buy it, if i don't know what to look for? :/
Nothing special! |
28th Feb, 2010 at 07:33:33pm
The first one
28th Feb, 2010 at 10:24:12pm
You have a lot more patience than I, Rod, good for you ! |
1st Mar, 2010 at 12:31:16am
On 28th Feb, 2010 tadge44 said:
You have a lot more patience than I, Rod, good for you ! yea, i am surprised that Rod still answering on my stupid questions and helping me to get idea of that staff :) but what can i do, if i dont have any knowlage about electric :(
he is my only hope to get my mini back on the road without spending lot of money which i dont have
Thank you Rod!!!!8-) Nothing special! |
1st Mar, 2010 at 01:21:14am
but where i can buy wire which will geive 12v? fucking brilliant, reminds me of me when i was trying to figure electrics out for the first time, "Turbo's make torque, and torque makes fun"
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
1st Mar, 2010 at 01:24:57pm
You got me thinking Rod because I know my 90' Mayfair is fitted with a ballast wire (pink/white), so I went out with a multimeter and measured 11.6 with the engine not running in position 2 on ignition?
1st Mar, 2010 at 04:07:18pm
First, if you are on a conventional contact breaker setup, and just measure the voltage at pos 2 it is hit and miss what reading you get.
3rd Mar, 2010 at 10:15:15pm
hi Rod :)
Nothing special! |
3rd Mar, 2010 at 10:35:58pm
The modules come up on eBay from time to time but you have to be carefull.
