| Home > Help Needed / General Tech Chat > Stubborn Pot Joint Removal | |||||||
23rd Feb, 2010 at 11:39:39pm
I am in need of some TM wizardry.
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
23rd Feb, 2010 at 11:59:20pm
bigger hammer??? On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
24th Feb, 2010 at 12:08:50am
I had one where the spring clip had broke jamming the joint in. I ended up using a long tyre lever either side and some good old brute force and ignorance! If in doubt give it a clout :) |
24th Feb, 2010 at 01:19:39am
These pot joints weren't bought recently from one of the big mini parts supplyers by any chance, I have just cut one off with this exact problem On 17th Feb, 2009 Rob H said:
24th Feb, 2010 at 08:16:04am
try a 5lb lump hammer or numatic drill |
24th Feb, 2010 at 08:24:13am
I find occasionally that the circlip gets distorted when fitting the pot which makes it impossible to get them off in tact I seriously doubt it! |
66 Posts Member #: 8258 Advanced Member |
24th Feb, 2010 at 08:24:35am
It seems to me that whoever fitted the pot joints all those years ago didn't apply any grease to the splines etc so I expect they have corroded onto the shafts quite solidly, or the pot joint splines were a very tight fit so the pot joints were hammered into place during installation.
24th Feb, 2010 at 09:08:27am
I'd say its probably the clip damaged as Paul says, how about trying to drill out the centre of the inside of the joint, so that you could then use a leg puller with the legs on the outside of the pot, and the puller pushing through your drilled hole, onto the end of the diff output shaft.
24th Feb, 2010 at 11:41:40am
On 24th Feb, 2010 Laurence said:
It seems to me that whoever fitted the pot joints all those years ago didn't apply any grease to the splines etc so I expect they have corroded onto the shafts quite solidly, or the pot joint splines were a very tight fit so the pot joints were hammered into place during installation. Surely, oil from the engine/box would find its way in here... On 13th Jul, 2012 Ben H said:
24th Feb, 2010 at 01:06:37pm
I doubt its rust the joints are not that old and gearbox cant be more the 18months since it was originaly built. It could well be that these are 'dodgey' joints.
24th Feb, 2010 at 01:17:14pm
Good luck Sprocket. I know how it feels to be on a bit of a back footer. Had nothing but trouble getting my most recent engine back in one piece. If something is worth doing, it's worth doing half of. |
24th Feb, 2010 at 01:58:01pm
Colin I would Supect that your problem is as I said the set I had where no more that 18 months old ether, I ended up having the cut the pot joint off where the surface the seal run on meets the large outer diameter of the pot joint, I tried drilling the center out of the joint but it was futile and recked 3 carbide cutters,
24th Feb, 2010 at 02:06:38pm
Yes, I was going to say that the pot joint outer cups are harder than glass so you won't be able to drill through, you'll have to use a disc-cutter (plasma) & cut away as much of the pot as you can then maybe cut along the the remaining outer shaft & split it off the splined shaft.
24th Feb, 2010 at 04:47:45pm
What is the proper tool? AlexF |
24th Feb, 2010 at 07:37:31pm
On 24th Feb, 2010 AlexF2003 said:
What is the proper tool? Sprocket I seriously doubt it! |
25th Feb, 2010 at 12:01:20am
What is the propper tool? Sprocket Oi, Wigo!
The propper (spelling mistake ^^ fixed ) Tool is one of these http://www.minispares.com/Product.aspx?ty=...NG%20TOOL%20m... And for once, I was pleasantly surprised how well it works. Just not on these joints Deffo worth having in the tool kit if you work on Minis a fair bit.
![]() 248 Posts Member #: 5007 Senior Member Crazyhill, Livi |
25th Feb, 2010 at 12:10:06am
I use this....
"se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
25th Feb, 2010 at 12:15:33am
On 25th Feb, 2010 MrOz said:
I use this.... http://tinyurl.com/yckh4wn (wouldn't let me post full url so had to use tinyurl instead) Just watch yer fingers..... That is a great idea. Mine has just gathered dust since going megajolt On 12th Nov, 2009 Paul S said:
Gary's description is best |
25th Feb, 2010 at 09:04:05am
The centre of the joint shouldn't be hard to drill - there is a simple pressed steel cap there that acts as a bit of a bearing surface for the other half of the joint. I have had these caps come adrift in use before now and fill the joint with oil!
25th Feb, 2010 at 09:46:32am
Nope only some of the joints have a cap in the centre if it's a replacment joint it will most likely have a solid centre On 17th Feb, 2009 Rob H said:
25th Feb, 2010 at 11:57:00am
So, who might the supplier of aformentioned difficult joints? On 7th Oct, 2010 5haneJ said:
25th Feb, 2010 at 11:58:23am
I too would like to know.
25th Feb, 2010 at 01:28:00pm
On 25th Feb, 2010 PaulH said:
Nope only some of the joints have a cap in the centre if it's a replacment joint it will most likely have a solid centre Yep, thats right. Something deffo needs to be drilled, milled or cut. Decided that the only thing that really needs butchering is the diff cage side, I will just discard the crown wheel side and replace that lot. On 26th Oct, 2004 TurboDave16v said:
25th Feb, 2010 at 04:40:41pm
25th Feb, 2010 at 07:04:18pm
Nope again its nothing to do with the person fitting the Joints,
