Home > Help Needed / General Tech Chat > turbo chamber enlarging head work
battleroc
Member #: 5620
Dunstable, Bedfordshire
Hi there
i have 2 heads
1 a spi head and 1 a metro turbo head
i need to lower the compression so i need to have my head chambers enlarged
what is a better head to use on a turbo set up?
as i have had 2 people say diffrent things
saying spi is better as its unleaded already?
also any advice on people/places to do the work
cheers
Dan
the unleaded point is a good point.
the turbo head will have sodium cooled valves.
I would go with the SPI head and stick a set of stainless exh valves in it.
The heads are essentially the same. I'd stick some bronze guides & stainless ex valves in the SPI head, job sorted !
If you're interested I can do any work you may require.
Phil.
battleroc
Member #: 5620
hi guys
cheers for the info...but is it not true bronze guilds and stainless valves don't last though?
(turbo Pete i sent a email on costs)
yes its not true. .......... they last
