| Home > General Chat > Help ??? | |||||||
18 Posts Member #: 8199 Member |
27th Feb, 2010 at 12:43:53am
http://yfrog.com/el20272133587472650815202j
![]() 248 Posts Member #: 5007 Senior Member Crazyhill, Livi |
27th Feb, 2010 at 12:50:44am
Page won't load for me. "se ne estas rompita, ne ripar ĝi - supercharge ĝi." |
27th Feb, 2010 at 12:52:15am
me neither Yes i moved to the darkside |
27th Feb, 2010 at 12:59:22am
27th Feb, 2010 at 12:59:34am
That Work ? |
27th Feb, 2010 at 06:51:58am
Not for me....
27th Feb, 2010 at 09:19:36am
Edited by Sprocket on 27th Feb, 2010. On 26th Oct, 2004 TurboDave16v said:
27th Feb, 2010 at 09:35:55am
Also, google plug welding for the joins, makes a much neater and stronger join On 11th Feb, 2015 robert said:
27th Feb, 2010 at 09:59:19am
On 27th Feb, 2010 Sprocket said:
It looks to me that the 'repair' doorstep panel is not full length. The genuine A post and doorstep panel is all in one, which would have covered that gap. Possibly but possibly a RHS repair panel fitted to the LHS. They look similar but the amount at the ends differ. Also, in the photo it looks like it is sticking out sideways too far and the door tread should be narrower at the front than the back so that could be the back is at the front (ie, again, it is the one for the other side). The two repair panels are mirror images, not identical, so can't be swapped from side to side. (edit - grammer) Edited by Rod S on 27th Feb, 2010. Schrödinger's cat - so which one am I ??? |
