Home > Technical Chat > Flat Shift on the Emerald ECM
MrOz
Member #: 5007
Crazyhill, Livi
Does anyone use this function? And is it worth it?
Granted it's not a difficult job, but just wondering if I should do it - it sounds like a great "toy" to have.
Edited by MrOz on 27th Feb, 2010.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi."
evolotion
Member #: 83
Glasgow, Scotland
depends on yhr engine setup, but i use it (on megasquirt admitidly) and its an absolute must to keep my turbo spooled :)
Denis O'Brien.
what on earth is flat shift then?
im in the mood for trying to learn somthing today......lol
A bit like launch control, microswitch fitted to clutch pedal or linkage somewhere so ECU knows when clutch is disengaged and, with throttle wide open (ie, foot flat on the floor, hence the phrase flatshift) limits engine revs to a set figure by retarding ignition and/or fuel flow. Thus for leaving the line or changing gear you never take your right foot off the floor and the ECU does the rest maintaining high engine speed and high exhaust gas flow to keep the turbine spooled up.
Not sure it would be so much use with a supercharger though....
