| Home > Help Needed / General Tech Chat > Carb help needed ? | |||||||
28th Feb, 2010 at 05:09:08pm
I have just installed and run in my fresh 1275 engine, which differs from the previous one in that it has now got M/T turbo pistons and a gas flowed exhaust manifold and turbo elbow, as well as a new 2" exhaust with a new RC 40 single big box, up from 1.75" and an old RC 40 big box..Both this and the other engine have a TurboPhil head and a Kent Cams turbo cam.
28th Feb, 2010 at 05:25:58pm
have you wound two dashpot springs togeather ? i know its a frig but....... give it a wirl
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
1st Mar, 2010 at 12:31:17am
Dave.
Edited by turbominivanman on 1st Mar, 2010. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
1st Mar, 2010 at 01:16:43am
In my limited experience (mostly na admittedly) ive not really found that to be the case tbh
1st Mar, 2010 at 06:26:20am
Thanks Richard. I should re-emphasise that the carb settings and general setup are unchanged from the previous engine which ran fine, although I did not have the wideband on then.The option to reinstate the lean off pipe is not available as in the past I ran a 1/8th drill down the stub nearest to the manifold, which appeared to have a little spring in there. I did try to reinstate but it wont run anywhere near !.I expect that the needle will have to be customised in due course.
1st Mar, 2010 at 06:26:35am
1st Mar, 2010 at 07:43:40am
sure its not icing up tadge? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1st Mar, 2010 at 01:20:48pm
I dont think so with my underbonnet temps,but will be test driving again this afternoon with revised ignitiion setting and different dashpot oil -again ! |
