| Home > Help Needed / General Tech Chat > constructing an Airbox | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
28th Feb, 2010 at 05:50:35pm
Hi guys.
28th Feb, 2010 at 05:57:11pm
Would something like this work:
28th Feb, 2010 at 06:20:13pm
it would, if i could fix it to the Carbs. that seems to be the tricky part. |
28th Feb, 2010 at 06:56:44pm
cant you attach to the screws that holds the ram pipes on and put them in the airbox. I run a supercharger and I don't care the TB is on the wrong side.
28th Feb, 2010 at 10:09:32pm
Dare I ask, what did the bike use as std to fix the carbs to the air box?
28th Feb, 2010 at 11:16:52pm
Can't use the screw on the On the ram pipes as the ram pipe is part of the inside of the carb it self.
