Home > For Sale > KAD Crank Sensor Kit & Internal Gear Linkage Kit - BRAND NEW
aml
Member #: 1662
manchester
Kit of parts to mount crank speed sensor and trigger wheel to the A series engine.
The kit is designed to mount a 122.5mm diameter Ford pattern 36-1 trigger wheel to AHU1878 or Poly V type crank damper via a mounting hub secured by the crank bolt. The sensor bracket bolts to the existing bolts on the cylinder block through the timing chain cover. Infinite trigger wheel adjustment position and fine adjustment of crank sensor. Crank sensor is variable reluctance electromagnetic type, with two pin minitimer type connector.
As new in box.
£120
Can post, only selling because I'm breaking my turbo mini race car build, loads of new parts for sale.
As new.
£150.
Edited by aml on 1st Mar, 2010.
blister
Member #: 2590
Croydon
dibs on the internal linkage but would like more information on it if thats ok
aml
Member #: 1662
manchester
Allows gear change housing to be mounted inside the car. All of the parts for the conversion (except the standard gear change housing) are supplied. Gearchange rod runs through top of tunnel connected by universal joints
http://www.kad-uk.com/accessories.htm
I assembled the gear stick & rods into a housing while it was out of the car to see what it was like & it's a really good fitment. It's never been used in a car.
blister
Member #: 2590
Croydon
oh ok so does it come with the quick shifter base (red) as in the photo and is that kad?
aml
Member #: 1662
manchester
The quick shifter base isn't KAD no. I'm not 100% sure it would fit, but I'd throw it in.
I think the only part you would need is the plastic bit that holds the gear lever in the housing (this isn't supplied with the KAD kit).
lockfast
Member #: 2775
Aberdeen
If blister doesnt want it I will have it please
aml
Member #: 1662
manchester
Ok.
I presume both of you would require postage?
cheers,
Ali.
lockfast
Member #: 2775
Aberdeen
Yes! Happy to arrange an uplift if you would be willing to parcel it up!
aml
Member #: 1662
manchester
Will give blister a chance to get back to me, if not, the linkage kit is yours.
lockfast
Member #: 2775
Aberdeen
no probs. Just let me know.
maccamcvey
Member #: 6673
Worral Sheffield
slim chance if both fall tro, If they do will collect week Friday cheers
aml
Member #: 1662
manchester
KAD internal linkage:
have PM'd blister.
1. blister
2. lockfast
3. the_soon_to_be
4. maccamcvey
(the_soon_to_be) PM'd me an hour or so ago.
wintersurferuk
Member #: 2208
pants :(
aml
Member #: 1662
manchester
5. wintersurferuk ?
haha.
Ali.
the_soon_to_be
Member #: 1600
Portsmouth, Hampshire
blister, lockfast.. take a £5er each to loose intrest haha
aml
Member #: 1662
manchester
haha.
blister has until:
2nd Mar, 2010 at 06:53:15pm
24hours to get back to me seems fair?
Ali.
aml
Member #: 1662
manchester
blister has dropped out.
lockfast has PM.
lockfast
Member #: 2775
Aberdeen
replied to pm.
the soon to be £6 quid might have swung it for you
maccamcvey
Member #: 6673
Worral Sheffield
did he take the 5er? will lockfast and soon to be take one as well? lol
aml
Member #: 1662
manchester
lol. sorry mate, lockfast is having it.
aml
Member #: 1662
manchester
Gear linkage sold pending payment.
Trigger wheel kit still for sale.
Ali.
hi mate i have been looking for crank sensor. can you pm me your email as my pm not working hope to hear back soon
Edited by madmk1 on 6th Mar, 2010.
aml
Member #: 1662
manchester
PMd
email sent mate
aml
Member #: 1662
manchester
awaiting payment for crank sensor kit.
