Home > Help Needed / General Tech Chat > MegaSquirt-II (v3 pcb) and boost control
Ok im a megasquirt retard
After looking at Bretts thread its got me thinking apart replacing my megajolt for something that I can datalog with.
I would want to run the unit but no fuel control (obviously), but then what do i need to add to make it control boost?
Any help put into idiots terms would be most appreciated!!
Do i need this http://www.diyautotune.com/catalog/pcbv3-a...dkit-p-160.html, a solenoid and some wires?
thats about the size of it Nic,
you should down load tuner studio (the tuning interface) and have a look.
http://www.efianalytics.com/TunerStudio/
you can map the boost against rpm and throttle position.
Buy VEMS and get Wideband, EGT and SD card datalogging too *tongue*
I expect Megasquirt will do the same, but VEMS also has gear/ boost.
Runs fir cover:$
Edited by Sprocket on 1st Mar, 2010.
lol,
fair points, especially if you are elecronically challenged,
I'd say if you intend sticking a K head on go with VEMS, if you want to push the 5 port and go to injection go MS.
Theres no way a 16v head will be going on my car
lol
Also its worth considering that BAT does looms for VEMS, ok they are for the K head, but wont be using the injector part (or could use it for a 7 port)
Bat would build a custom loom for Nic with only that he requires. TBH its nothing taxing, its just a matter of ticking the right boxes on the order form.
Don't forget that you can now do traction control with MS even if only using it for ignition.
Argh another spanner gets thrown into the works!
I have no problem with the loom, but all of this circuitry nonsense and different versions of the megasquirt has lost me slightly
it is quite confusing,
essentally (IMO) though it comes down to two choices,
siamese code (beta), or the latest MS2 extra release code.
you can then configure whatever hardware (sensors etc) you have/can get hold of to work.
once you actually look at the circuit schematics of the pcb theres suprizingly not that much there that you have to worry about,
in your case mainly the crank sensor,
tps, coolant, MAT & boost sensors will be genric or just a change in settings.
you have no idle valve to worry about, no injectors,
anyway, theres enough people on here that are familiar with it if you do get stuck.
If i built it with the MS2 code and then wanted to go injection later is it a case of flashing the chip for the different codings, or are they built differently?
Is there any disadvantage for using the siamese code? will it stop me being able to do anything?
The code you would use would be the MS2-Extra code anyway. The siamese code is now effectively a part of the Extra code so whether you just want ignition plus boost control, launch, etc, it's all there.
The only differences in the build are minor with respect to ignition (ie, coil, coilpack, or COP/CNP) and more significant with respect to fuel injection (single injectors, multiple injectors, staged injection, low Z vs high Z) but with the more significant injection options they can all be backfitted later.
If you just want boost control and datalogging, then you could just get an Apexi AVC-R and an electronic dash with a data-logger built in.
You don't want to think about using injection. It's too complicated, it won't make any more power plus it will make my task of beating you harder *happy*
That sounds far too expensive
The trouble with the MSII boost control is that it is rpm based. What we really need is gear based boost control.
Gear based boost control will be available with the MS3 version currently in development but that may not include the Siamese options.
On the Miglia we are going to start with using the MS but will probably upgrade to the APEXI.
Of course there is always the possibility that we will not need boost control if the traction control is effective.
jbelanger
Member #: 831
Montreal, Canada
Gear-based boost control is likely to make it to MS2/Extra. Also, it is planned to have siamese-port options on MS3 but it may not be right from the start.
However, I'm not sure MS3 will bring that much more to justify the cost difference but that may change as development progresses.
Jean
http://www.jbperf.com/
Did you get any further with this ?
A quick question, will all Megasquirts work with my current 36-1 trigger wheel & edis setup from my megajolt, so I can just swop the ECU's over ?
sturgeo
Member #: 1778
Northants
On our test bed i can see the boost control working depending on rpm.
In theory you can just swap them over with a few additional sensors but personally i'd ditch the edis and drive the coilpack directly, this will give you lots more features to play with :)
Great thanks. So do I need a certain version to be able to do this ?
no,
just the right code and extra coil driver chips, VB921's or BIP???
I think i have some VB921's I could send up with my head Phil, I'll look tonight
Edited by Joe C on 3rd Aug, 2010.
and space in the box to fit them (if it's a standard build the heatsink will be full so you will need to make another or bolt the two ignitor chips to the casing).
VB921s are now obsolete I believe.
BIP373 are the Bosch equivilant but are pricey and only from a few specialists.
ISL9V5036P3 or IRGB14C40LPBF are suitable chips (I used the ISL one) but have to be fused as they have no built-in current limiting.
But, as already said, if you have an MS2 dump the EDIS, put the two ignitor chips in and use the Extra code.
EDIT - I should add that if you are going to do the boost control with a proper PWM (modulating) control valve - which is how the current MS-Extra code expects you to do it - you also need to upgrade one of the MS2's transistors to a bigger one which also has to go on a heat sink.
If the MS2 is built for ignition only there will be plenty of space on the existing heat sink as the injector drivers don't have to be installed on the existing heat sink but I found it easier just to add a second heatsink - keeps all options open.
Edited by Rod S on 3rd Aug, 2010.
no,
That would be great, thanks Joe. I'll have a proper chat with you at MITP as you seen clued up on this & I'm still learning.
Ill eaves drop on this conversation!
No Probs,
If i get time i'll pull my ecu and bring it along.
