Home > Help Needed / General Tech Chat > O/T - Need help with Uni project (Electronic device)
MrOz
Member #: 5007
Crazyhill, Livi
I'm trying to build a circuit that will once activated will cut the power to the fuel injectors, it needs to be done sequentially with approximately 60 seconds between each injector being shut off and the power will remain off until the reset button is hit.
I've been looking for some way to do it using a 555 timer (or 556), but it's been far to long since I played about with them that I can't figure it out.
Anyone able to help?
If not I'll need to write a program in either VB or Java to simulate it - it's not gonna be the same and might have an effect on my marks, but that's the way the cookie crumbles.
"se ne estas rompita, ne ripar ĝi - supercharge ĝi."
metroturbo
Member #: 989
North Yorkshire
My electronics knowledge is slowly dying, but my thought was the first injector is killed by what ever is activating the shutdown via a simple control circuit, and also kicking off a timer at the same time. After 60 seconds this timer and its associated control circuit shuts down the next injector and also starts the next timer circuit, and so on. Basically a cascade of timers shutting down the injectors. There is probably something simpler, and all within one chip, but this principle would work.
Ben H
Member #: 184
Melton Mowbray, Pie Country
forget 555 timers for a long period of time, they are not made for that. Try using a simple pic controller, then you can make exactly what you want.
http://www.twin-turbo.co.uk
MrOz
Member #: 5007
Crazyhill, Livi
Thanx chaps - the only reason I was concidering 555 timers was that's what I'm used to using.
I suppose if a pic controller was used it would be more "real world".
cheers for the input - 'tis appreciated.
